DIY changing Transmission Fluid
So all the engineers who have designed and created this system to require no flush are wrong? The company is just stating it's sealed so they don't get to sell you another service? You see where I'm going with this? You are changing fluids that do not need to be changed. Your feeling of a better shift is in your head. The "feel" of the shift is controlled by your ECT-i so unless you rebooted that, you are not shifting differently.
You are not letting go of old ideologies on how a car is engineered. As a engineer, I can tell you things change from year to year.. we have made massive leaps. Oil lasts 20k now, internal tolerances are so exact it's measured in 0.0000 distances. Volumetric efficiency is so good on your 18 NX that is defies most basic VE calculations.
That being said, if you want to change your trans fluid, go for it. But @ 30k?! wow. "life of a vehicle" can be interpreted as around 100-150k, So a flush around those miles would make sense to me. What exactly are you thinking is happening to the fluid in 30K?
That's because you and the tech don't understand the science behind it.
Also, that Toyota tech probably knows less about the car than you do. They are just parts replacers, truly I'm not being sarcastic. They use a system called Alldata to hold their hand on what part to replace and why. Short of the shop foreman, those guys probably would have trouble telling you how a internal combustion engine works.
But I digress, do as you wish.. change every 2k man, why not?
2 things..
1) You are changing at 30k, not 80k. I stated changing at higher mileage doesn't seem outlandish
2) What you think is happening to the trans fluid? Stop, don't google it... What do YOU think is happening to the fluid? This will help me help you with the science of the fluids.
I will agree, the zinc, monomer and other additives will break down over time. The time it takes is much longer than your father's ford.
2 things..
30k miles seems a bit early to me. Our w211 I believe requires it at 60k miles and that even seems excessive to me but it's in the book so that's what I do. I definitely don't agree with "lifetime" changes... that to me doesn't make sense. Over time the fluid will change just like anything. Fluid is cheap compared to a new transmission. I haven't even looked yet on the wife's NX but I am guessing there is no trans dipstick... So it's harder to tell the color of the fluid without draining it. The w211 is the same way in terms of when you have to refill the system you do it through the drain plug at the bottom which makes it a bit of a pain compared to most normal vehicles that have a standard drain plug and then dip stick tube. My wife's Solara I changed the tranny fluid once at 100k and it was still rather pinkish but more of a red color. Then just did a drain and fill of the pan which netted me about 4.5qts. I figure at almost 200k miles that's more than fine and I'm sure more than what most people do. I'll just keep doing that because it's easy the fluid is still pink at 50k+ miles. My truck I normally just disconnect the return line and pump out 4qts, then fill 4qts and repeat the process until the return line is draining new pink trans fluid.
-Nigel
-Nigel
IS250blue
09-05-22 01:43 PM
