NX - 1st Gen (2015-2021)
Trunk misaligned NX200T 2016
Old 10-16-17 | 07:25 PM
ayman01's Avatar
ayman01
Default Trunk misaligned NX200T 2016
Hey guys!
Need your advice.
Just yesterday I noticed that the gaps on the left and right on the trunk do not match. I took the ruler and on the left 1 cm gap (0.4 inches), and on the right 0.7 cm (0.27 inches).
It's very strange because the car has never been in an accident. The liftgate was never removed.
Do you think this is normal and acceptable or I should go to the dealer and ask them to fix the trunk door somehow?
Thank you.
Old 10-16-17 | 09:18 PM
miop4000's Avatar
miop4000
Originally Posted by ayman01
Hey guys!
Need your advice.
Thank you.
Noticed the same thing.
Took it to the dealer and they photographed the rear and measured the gaps.
They said it was within tolerance.
I suspect its the fact the trunk is motorised. Its under tension from the motor when closed. The trunk is pressed against rubber stoppers. Any variation to the tension on either side gives a slight uneven gap.
So much for Lexus flawless panel gaps.
Old 10-16-17 | 09:47 PM
ayman01's Avatar
ayman01
Wow, Lexus disappoints me more and more. I will take it to a dealer tomorrow. Hopefully, they can fix it somehow. At least I am not the one...
Thank you for your response and information!
funcrusher
34
05-07-19 08:13 AM
chrisv78
05-29-13 10:37 AM
Rustito
09-22-09 07:30 PM
sk72
ES - 5th Gen (2007-2012)
01-17-09 09:30 PM
reddlexus
SC- 1st Gen (1992-2000)
05-30-06 01:23 PM
