Why can't I adjust the volume from my car when a call comes in?
I just got a brand new NX300. When a call connects, I can barely hear anything through the car speakers and adjusting the volume via the car controls does not work. Once I manually adjusted the volume on my phone, all was ok.
Shouldn't the volume be adjustable from the car when a call comes in?
Thanks for your reply
Then what's the point to SW volume controls? As they surely do not adjust volume while in conversation. Good luck using pointer, while driving, to hit volume + button on display. Then again, why do we even have volume control on SW?
He’s not referring to a pointer, he is referring to the volume **** below the screen. I don’t know if this works as I’ve not tried it, the volume for us is good.
Go to Menu>Phone>Settings> Sound> adjust volumes as you wish. Ringer volume, incoming call volume. Those are set though, after you adjusted them. Hence, if it's too loud now during call, simply knock it down on phone volume control. Easier.
shaxs
ES - 5th Gen (2007-2012)
12-14-18 11:21 AM
