NX - 1st Gen (2015-2021)
NX Phone holder recommendations (merged master thread)
Old 07-22-17, 10:20 AM
  #91
user 2920842
4th Gear
user 2920842's Avatar
Originally Posted by oldwineguy
I use a ProClip
I am interested in installing a ProClip, it looks like the best solution for my needs. Could you post a picture from the driver's position of the mount and the mount with the phone? I'm curious how it looks when it;s installed and if if blocks the screen.
Thanks in advance.
Brian
Old 07-22-17, 11:00 AM
  #92
dvan7286
dvan7286's Avatar
Default Phone mount
Thanks in advance.
Brian
I can't figure out how to add a picture but there are pictures on the Amazon page for the wizgear. I looked up information on the pro clip and it is a permanent installation. The wizgear has a padded clip and easily removed and does not cause damage.
Old 07-22-17, 10:18 PM
  #93
oldwineguy
oldwineguy's Avatar
Thanks in advance.
Brian
I'll tried a bunch of different mounts and though cheaper, none work as good as the ProClip. I moved mine over to the right a little to make sure it cleared the NAV screen, but is still easy to acess.
The ProClip is not a permanent installation, it can be removed with no damage.
user 2920842 (07-24-17)
Old 07-23-17, 01:25 AM
  #94
zkl2003
zkl2003's Avatar
Default iOttie Easy One Touch Mini CD Slot Car Mount Holder
You can turn the mount more to the left toward you and it won't bother you to shift gears at all. even it does look super close and on the way. The only down side is that it might block the little storage area above the CD drive.
The following 2 users liked this post by zkl2003:
gooddawn (06-07-19), Mandon75 (11-05-19)
Old 07-23-17, 02:09 AM
  #95
dchar
dchar's Avatar
This is my favorite phone mount. Allows easy mounting and dismounting of phone without needing magnets or weakening and blocking air vents.
Old 07-23-17, 05:47 AM
  #96
Lex2000TL
Lex2000TL's Avatar
I use magnetic holder. It holds the phone very securely and I do not have to fiddle with clamps to place phone on or to remove it. The holder itself is attached by 3M tape and can be removed without any damage to a dash trim.
Old 07-23-17, 11:11 AM
  #97
LHLXD
LHLXD's Avatar
Old 07-23-17, 12:00 PM
  #98
zkl2003
zkl2003's Avatar
Same here!! I also like to avoid blocking air vents or anything that is easy mounting rather than the one hard to dismounting. Cheers!
Old 07-24-17, 06:34 PM
  #99
user 2920842
4th Gear
Thanks, that looks better than I envisioned it from the pictures on the ProClip site.
Old 07-24-17, 07:03 PM
  #100
Lazerboy
Lazerboy's Avatar
Have you tried to put it in the dash upward and make a kind of HUD display out of it? I know there a couple of HUD app that lets you do this.
Old 07-24-17, 08:30 PM
  #101
oldwineguy
oldwineguy's Avatar
One of the things I like about it versus many of the other ones shown here is that it keeps the phone up more at eye level instead of having to look down at it if needed.
Old 07-25-17, 09:08 AM
  #102
aztr0
aztr0's Avatar
Like LHLXD above, I got an Anker magnetic car mount. It is small and works great. The magnet is strong and keeps my iPhone 7 plus with case stuck on tight. When I was testing it by trying to shake the phone off before mounting it barely moved. Would recommend if you're one of those who don't want a big mount that's in your face.
Old 08-01-17, 02:17 PM
  #103
spins123
spins123's Avatar
Using the iOttie mount. So far so good.
oleglap (01-02-18)
Old 11-28-17, 03:36 AM
  #104
lhcox
lhcox's Avatar
Default cell phone mount lexus nx
Is there a cell phone mount that works with the NX?
Old 11-28-17, 09:23 AM
  #105
typocl
typocl's Avatar
I use a magnet vent holder in the left vent. Here's some others:
https://www.clublexus.com/forums/nx-...-location.html
Quick Reply: NX Phone holder recommendations (merged master thread)
