NX - 1st Gen (2015-2021)
Brake Life
Old 10-31-18, 09:58 AM
gompka
gompka's Avatar
Originally Posted by ukrkoz
Nope. Fancy tool is required:
When not Using the Techstream:
  1. Turn the engine switch off.
  2. Using SST, connect terminals 12 (TS) and 4 (CG) of the DLC3.SST:
    09843-18040
    NOTICE:
    Do not connect the wrong terminals, as this will cause parts to be damaged.
SST tool in this case is a short piece of wire....
Old 10-31-18, 10:00 AM
ukrkoz
ukrkoz's Avatar
Or, as I said before, entire assey needs to be removed:
We replaced the rear brakes on my NX by removing the parking brake motor and manually turning the piston/screw that the motor's shaft inserts to with either a Torx or Allen wrench (can't remember). Once the replacement is complete, the motor will turn a little longer than usual the first time you operate the parking brake since you pushed the piston/screw all the way back and it's re-calibrating itself. This will throw a one-time code. Just reset it and you're done.
Old 10-31-18, 10:02 AM
ukrkoz
ukrkoz's Avatar
https://toyotacanada.service-solutio...09756-48020-1B
Old 10-31-18, 10:09 AM
gompka
gompka's Avatar
Always an option, just need to buy the o-rings. Seems like its not that hard to do with the procedure to put them in replacement mode either. WIll have to give it a try one of these days. I have done similar procedures for work on other Lexus cars and although they are cumbersome they do work. I will probably just spend the $40 buy a techstream cable though since it will come in handy for other things as well.
Old 10-31-18, 11:19 AM
ukrkoz
ukrkoz's Avatar
Indeed. I already tried several cables and it always was a flop. And I tired even very old laptops, with old windows - still no go..
That machine in case does not look like "just a wire" to me. With unknown price tag and to be used twice in car ownership life.
I watched VW guy, he simply removed e brake module and did the job.
Well, someone will do it sooner than us. My pads are at 85% and I am easy driver.
ByoungWoo
Suspension and Brakes
10-22-08 09:48 PM
mdk77
Chicago Lexus Club
08-09-08 03:37 PM
rclab1
05-05-07 01:00 AM
LexLS
Maintenance
10-23-03 12:46 PM
abutler696
SC- 1st Gen (1992-2000)
15
01-10-02 02:14 PM
Quick Reply: Brake Life
