NX - 1st Gen (2015-2021)
DRL Question
Old 01-06-19, 07:12 AM
2016 RX350
10th Gear
2016 RX350's Avatar
Default DRL Question
On the 2018 NX300 should the DRL stay on when the the turn single is used. Also should the DRL stay on when the vehicle is remote started.
Old 01-06-19, 08:41 AM
TechNut
TechNut's Avatar
The daylight running light changes to a yellow turn signal on our 2016. I’m not sure if the DLRs are on when using remote start, but I believe so, assuming that is the position of the switch on the light stalk.
Old 01-06-19, 06:03 PM
Newnx
Newnx's Avatar
The DRL turn off when turn signal is on.
Old 01-07-19, 04:25 AM
2016 RX350
10th Gear
2016 RX350's Avatar
The reason I ask is because my wife and I have the same vehicle same options only difference is in color. My DRL stay on when the turn single is used.
Old 01-09-19, 07:38 PM
legrunt
legrunt's Avatar
Check what time of the day you are testing that. Cos at night, the mode of those lights change from "DRL" to "Parking Light" and dims. That stays on when the turn signals are used. In full brightness DRL mode, that should switch off when the turn signals are used.
Old 01-12-19, 12:53 AM
dchar
dchar's Avatar
The DRL will not come on when remote started since the DRL actually normally don’t turn on until you shift out of Park.
Old 01-12-19, 08:17 AM
Lex2000TL
Lex2000TL's Avatar
My NX DLR turn on with remote start.
Old 01-12-19, 10:30 AM
TechNut
TechNut's Avatar
The DRLs on both our 2015 ES and 2016 NX turn on within a couple second of starting the car. That is why I assumed they did with the remote start. So the statement above does not reflect the behavior of either of our cars.
However, just to answer this question for myself, I remote started our 2016 NX and the DRLs did NOT come on. Since dchar’s observations do not match my own, I suppose it is possible that this behavior varies by model year or perhaps a setting the dealer can apply?
xfumbler
07-18-17 01:35 PM
Maratonez
01-27-16 03:29 PM
Luke27617
05-16-13 09:15 AM
jgarrido
03-03-12 10:36 AM
khpark928
05-05-11 08:44 PM
Quick Reply: DRL Question
