NX - 1st Gen (2015-2021)
interesting find on Alixpress
Old 02-18-19 | 08:22 AM
aribter's Avatar
aribter
Default interesting find on Alixpress
Not affiliated with this product at all, but for less than $40 CAD I thought it was worth a try.
https://www.aliexpress.com/snapshot/...Id=32732889125
It will probably take a couple of months to arrive, I'll post a follow up if anyone is interested.
Old 02-18-19 | 12:37 PM
codenko's Avatar
codenko
CL Folding 10,000
It prompts for a login. Doesn't actually go to any product.
Old 02-18-19 | 12:56 PM
aribter's Avatar
aribter
Old 02-18-19 | 03:30 PM
ukrkoz's Avatar
ukrkoz
Naahhh... another remote to get lost... and I see use for it only maybe real hot summer day. To let hot air out.
Old 02-18-19 | 06:14 PM
MKenM's Avatar
MKenM
Not sure if you read it correctly there is no additional remote required. uses your existing fob.
Old 02-18-19 | 06:29 PM
aribter's Avatar
aribter
Yeah it's not an extra remote. It's something you plug into the NX's OBD port.
Old 02-18-19 | 06:33 PM
ross7777's Avatar
ross7777
I thought this could already be done?
Old 02-19-19 | 07:11 PM
aribter's Avatar
aribter
you can program the key fob to roll the windows down but not up
Old 02-20-19 | 03:11 AM
Djkb's Avatar
Djkb
Yep, Down and Up. Mine is done ��
Old 02-20-19 | 05:38 AM
nigel821's Avatar
nigel821
Yep using techstream you can have the fob make the windows go down. Techstream doesn't allow the windows to be put up though from the keyfob. Which is kind of annoying since our mercedes does both.
I don't know if I'd want to keep another thing just plugged into the OBDII port. I wonder how it forces the windows up. Makes me wonder then why there isn't an option via techstream to do so...arg!
Djkb: what did you use to make the windows go up?
-Nigel
Old 02-21-19 | 07:29 AM
nigel821's Avatar
nigel821
Wanted to update. I don't think this would work on US marketed NX's. I say this because of according to what I have found US marketed NX's ecu is coded in such a way that it's not like what Rest of World (ROW) get. The following from manual EU vs US:
"one factor might have been Federal Motor Vehicle Safety Standard (FMVSS) No. 118 (49 CFR §571.118), paragraph S4(d), which requires that a remote control for power windows must be “incapable of closing the power window [. . .] from a distance of more than 6 meters from the vehicle.”
In Europe (emphasis added):
■ Power windows and moon roof
Mechanical key linked operation (open)
Mechanical key linked operation (close)
Wireless remote control linked operation (open)
Wireless remote control linked operation (close)
Mechanical key, wireless remote control linked operation signal (buzzer)​
In the U.S. (emphasis added):
Wireless remote control linked operation (open only)
So if you are in the US this more than likely will not work, but always open if someone wants to test.
-Nigel
Old 02-21-19 | 04:28 PM
Djkb's Avatar
Djkb
I’m in the UK, the Lexus techs here programmed mine when I asked for it to be done. It’s a useful option when the weather is hot (not very often tho ��)
Old 02-21-19 | 04:56 PM
GS3Tek's Avatar
GS3Tek
-Nigel
For the US, I think it "MIGHT" work because you can still roll up all the windows by inserting the key and turning it.
Yeah, someone in the US will still have to verify this since I see the buyers are from the non-US and the pictures show RHD lexus.
Old 02-21-19 | 04:57 PM
aribter's Avatar
aribter
I'm in Canada, and I ordered this item, so I'll post an update soon as I receive the product.
Old 03-12-19 | 07:06 PM
aribter's Avatar
aribter
Update: It works as advertised. When the windows are down clicking the lock button on the key fob will raise any open window.
Now for the bad: my hazard lights flash whenever any door is open. I have emailed the seller.
