turn off car but leave accessories on
I have a 2019 NX. How do you turn off the engine but leave the accessories on? Sometimes when I stop I want to keep listening to the radio but turn the engine off. Seems like I am always turning it completely off then turning on the accessories only which requires a reboot of the system. The only way I can do this seems to be to put the car in neutral and then turn off. But if your on a hill this doesn't seem to work because you can't leave your foot on the brake.
ukrkoz (03-07-19)
Hit the stop start button, when car turns off hit the button twice without putting your foot on the brake, That will put it in accessory mode. Hit the button again without touching the brake pedal and that will turn the car off.
Maybe on your cars. On mine it takes way more than 10 seconds. Nothing moves fast in my infotainment. Switching between displays, volume adjustments, everything is molasses.
Stop watched it.
22 seconds till map comes up.
3 seconds after pressing Home button.
2 seconds for Volume number change after it was actually done.
Call it whatever you want it. It is slow for 21st century electronics.
I guess they improved it in the 2018 refresh. Mine is very responsive.
One press of the Start/Stop button with your foot Not on the brake is radio only Accessory.
Two presses of the S/S button with out foot on brake is radio and power windows/sunroof Accessory.
Shut down while in any gear position Except Park with or without foot on Brake then put in Park will enable Accessory.
When leaving the car be sure to press S/S with out foot on brake to really shut her down.
changhiskh
RX - 3rd Gen (2010-2015)
03-24-19 08:01 AM
revhigh
12-05-13 07:52 PM
cheappc
05-20-08 10:05 AM
swisslexusclub
02-10-06 02:49 PM
