Lock on (Lexus) Data Port
I apologize if this topic has been posted before. If so pls direct me to such thread. Otherwise, as I already knew about this report and took the plunge on a NX 200t F Sport, I wonder if this forum can shed some light on such protection to the SUV's Data Port?
https://www.cp24.com/news/york-polic...suvs-1.4286705
Thanks!
Dave
Thanks!
Dave
Thanks for sharing. I'm not aware of Lexus cars being targeted specifically, but in general, it seems that "keyless" cars are quite vulnerable to electronic carjacking. The thieves try to get access to the entry code by hacking the electronic access keys (or cards), as the radio signals can be intercepted over quite some distance:
https://edition.cnn.com/2019/01/28/e...ntl/index.html
Good countermeasures can be found here:
https://www.wikihow.com/Prevent-Keyless-Car-Theft
Up to now, I thought Lexus had a higher immunity against these frauds, at least here in Europe.
Great device! I wasn't aware so much about OBD hacking, quite worrying indeed. I just read through the installation manual: not so easy to install, but once done, seems to offer pretty good protection.
Obviously it doesn't protect against radio signal hacking of keyless access systems. This protection must be handled separately.
Next level of criminal car stealing will be by drone in front of your house
Key fob can be turned off: holding Lock button (down), pressing Unlock 2X; turning it back on by pressing any button. I have not tried this yet, meantime put them in the kitchen table and INSIDE a tin can.
CareAllend (06-25-19)
https://www.wired.com/2016/03/study-...ignition-hack/
I used tin foil, the one to wrap and keep your burger/pizza warm, just double the layer to wrap my key fob and walked to the car door. The aluminum foil cover is enough to stop RF transmission that I could not open the door as usual. Un-wraping the foil at the door and soon enough, the normal opening sound/clicking were audible, doors were open.
At the risk of sounding paranoia, I lined the box/case holding the key fob with tin foil to create such Faraday cage, as it works to stop RF transmission between the car and key fob, and put this box close to the door (no need to put them in the freezer ).
What is scaring is the fact that this hacking trick even works when you're walking, shopping or dining in a restaurant with your (unprotected) key in your pocket, if the partner of the gang is standing or sitting close to you; some friendly thieves might even try chatting with you
I even suspect the method can work over hundreds of miles with the right transmitter technology (e.g. over mobile phones) … Ok, phase delays might make this more difficult!
Thanks!
Dave
Thanks!
Dave
GXMilton (07-15-21)
They are not targeting the OBD port, why would they when its much easier to just do a wireless relay attack on the car. I would take preventative action and get an rfid key pouch and then not worry about the rest. If they really want it they will get it one way or another.
For my piece of mind I use a RF blocking faraday key fob case to prevent wireless relay attack. To prevent access to the OBD port I ended up using AUTOCYB (https://autocyb.com/).
gompka (07-19-21)
Kadence
02-03-10 03:34 AM
