Manually adding optional speakers?
I own the 2019 F Sport
So when I bought my NX i stuck with the base sound system, which is 8 (or is it 9?) speakers. One of the options available was a 10 speaker setup that came with the navigation package, then also some premium Mark Levinson package.
Where would the location of the 10th speaker be for the regular navigation package? Is wiring already there? From what I've seen so far there is a tap in the right rear corner in the cargo area. What type/size of speaker is usually included in this package? Can I order the trim mouldings so that I could just place my own speaker back there?
What about speaker locations for the Mark Levinson package? Where are these positioned?
The 10 speaker system adds an amplifier and two speakers - 8 inch woofer in the tailgate and a center channel.
The ML system adds 2 more speakers into the C pillars.
As you don’t have an amplifier (I may be wrong here - ask the dealer) I am not sure if the system is wired - best way to find out is take off the back right corner panel and see if the harness is there.
Please see my build thread for a picture of the factory amp and harness.
Look in here for amp picture.
If you’re like to improve the sound focus on upgrading the front dash speakers and door speakers first. There are some threads on how to do that here. More speakers do not equal better sound. Better speakers installed properly is the better way to go.
As for base adding an amplified sub under the seats or in the hatch will round out the system - all depends on your budget.
I'm not looking to spend much money. I figured it would have been an easy add-on but I guess not. If better sound can be had by replacing the front dash & door speakers, any suggestions on how to proceed? Bear in mind I have literally zero experience doing this but I'm not afraid of giving it a try.
In my experience, changing the speakers without adding an amp will not be enough to satisfy, and in some cases sound worse. The speaker placement and type of drivers used in these vehicles were engineered to match the under powered factory amp plus the amp's kooky x-over points.
I would suggest adding a powered sub if you don't have one already.
Figured I would post an update on what I decided to do based on other linked threads. So far I've replaced the front dash speakers as advised, I went with the Focal IC100. If you cut off 2 of the metal mount pieces, it will just barely be able to fit between the plastic inside the speaker area. Instead of soldering I used some spade disconnects and crimped them onto the existing factory wire after cutting off the OEM connector, for which I could not find any sort of aftermarket harness that could fit it. It's a tight space to work in but easily accomplished and I'm getting some improved sound already. Next I'll give the woofers in the front doors a try.
Adding to that you can experiment with different foam materials in hollow areas. Not recommended in the doors though because of moisture.
What do you think about Focal ICU100 then your IC100?
Hifiman1
12-20-17 12:15 AM
