NX - 1st Gen (2015-2021)
pic of my old 40k sparkplugs
Old 10-20-19 | 05:06 PM
Torii's Avatar
Torii
Default pic of my old 40k sparkplugs
no idea if really needed but followed the lexus recommendation of every 40k.
Old 10-20-19 | 09:56 PM
Torii's Avatar
Torii
if anyone sees anything that should be addressed....
Old 10-21-19 | 09:50 AM
E46CT's Avatar
E46CT
they look perfectly normal.
Torii (10-21-19)
Old 10-21-19 | 11:58 AM
Lex2000TL's Avatar
Lex2000TL
Second from right looks a bit too oily, but this may be just the way picture shows.
Torii (10-21-19)
Old 10-23-19 | 09:33 AM
olgzr's Avatar
olgzr
I replaced mine about 2 weeks ago. They looked just like yours. I also checked the gap. It was still in tolerance. The car runs the same with the new plugs.
Old 10-29-19 | 03:03 AM
acheuk's Avatar
acheuk
The middle two look more worn out than the others, but look normal to me.
Old 10-29-19 | 08:05 AM
no1SomeGuy's Avatar
no1SomeGuy
Not too bad, little bit of blow by on the tops of the plugs too (as is typical on turbocharged engines). Electrode wise they look okay, but the engine does run a bit rich hence the blackening. I can see why they recommend this sort of change interval, while they are definitely not finished, they aren't as clean as what you'd get on a naturally aspirated engine at that mileage. You could probably push them another 10-20k without too much loss in efficiency.
Old 10-29-19 | 07:25 PM
ukrkoz's Avatar
ukrkoz
Someone needs to come up with plugs designed specifically for high compression engines.
They all have exhaust leak past insulator.
#3 from the left is covered in oil, so there is internal oil leak from somewhere.
#1 is following suite, just not as bad.
Old 10-29-19 | 07:49 PM
Torii's Avatar
Torii
I have read engine oil is responsible...mainly calcium additives. this area I have no clue, but engine oils are different.
shaitaan
SC- 1st Gen (1992-2000)
23
07-20-08 10:54 PM
Luder94
10-02-06 05:57 PM
LexFather
05-08-06 04:04 PM
GSTRANCE
10-08-03 12:39 PM
