NX - 1st Gen (2015-2021)
Problem with "easy access" system
Old 10-31-19 | 05:19 PM
Hoobert's Avatar
Hoobert
Default Problem with "easy access" system
Hi,
Normally this system shall work like this:
1) turn off ignition
2) driver's seat is moved back (and steering wheel which works fine so I skip it)
3) get off
4) get on
5) turn on ignition
6) seat is moved forward
Now this system does one extra thing. At step 4, when I just open door, the seat moves forward and after turning on ignition it moves again pushing my knees into dashboard.
What I observed is that it works fine if I first open any other door but driver's. It's also interesting that even if I turn this system off seat moves when I open door.
Anyone experienced similar issue ? Maybe there is some way to reset this system ?
Thanks&Regards
Old 10-31-19 | 08:59 PM
Lex2000TL's Avatar
Lex2000TL
I started having very similar behavior with easy access and memory seat for last few weeks. I also noticed that while moving, seat was jerking a bit. So, before going to a dealer decided to lubricate seat slides with silicon lube. I know this is crazy, but for now (couple-three days, so far) the issue is gone.
Old 11-01-19 | 03:18 PM
Hoobert's Avatar
Hoobert
In my case seat moves smoothly. I was at diler's but they just did some superficial investigation even without computer and concluded that it's likely "comfort module" for 1.5k. I am not convinced as it happens also when whole feature is turned off. I will be visiting another dealer.
SAVLC500
03-01-24 12:23 PM
agibson
05-21-17 05:48 PM
Boomin
10-26-15 09:49 AM
lynhnn
RX - 3rd Gen (2010-2015)
11-19-13 04:50 PM
Rgrenader
HS 250h Model (2010-2012)
07-27-11 08:38 PM
