2020 NX300 Navigation scale seems way off
I got a new 2020 NX on Monday and it seems to me that the navigation scale is off by quite a bit. In my '17 IS200t the default 300ft scale represented streets etc. to be fairly close to the vehicle. It's been the same way in the other 3 Lexus vehicles I've had before. But in this '20 NX 300ft looks more like a half of a mile or more. I haven't been into detailed settings yet to see if something is just set wrong but I don't know how that could possibly be. 300ft should be 300ft regardless. I also need to try and come up with a different color scheme for the map. Light gray letters on a slightly darker gray background looks very fuzzy to me especially at night.
Here is an easy way to find out how accurate your map is. Use this link https://www.gmap-pedometer.com/ go to a cross street in your neighborhood pick a point and start (tell the map that you are walking) and then pick a stop point. It will tell you the distance and then drive it. Or you can use a town map to see the street frontage of properties in your area.
Many more was to check accuracy. Just a thought.
sleepybobcat
10-01-01 07:12 PM
