JB4 & NX200t
JB4 & NX200t
Had to get a mechanic to put this in because I could not release the tab to pull the plugs out of the TMAP and MAP sensors. He had a difficult time with it too. but $80 later at least it is in.
Initial Review: It seems to pull quite a bit harder but not ridiculously more. I have it set to map2 right now and I also got a K&N drop in filter for right now. I don't think I want the crazy sound of the AEM open element filter. To me the car drives like it probably should have from the factory. I would call it 'peppy' not fast but totally worthwhile. Ended up being more than I wanted, it was $569 with the iOS connector and $80 to install and I may have to figure out how to remove for warranty work as I have a 5 year warranty with it or just leave it in and see what they say.
Turbo Lag is unchanged I would say.
Conclusion: 8/10 and would rate it as a must have it you prefer a car with more spirited drive. Does not make it a sportscar but probably how it should have been from the factory.
DOUGLis350 (02-23-20)
