NX - 1st Gen (2015-2021)
Which fuse/relay control the a/c compressor
Old 06-01-20, 03:47 PM
Gjjason
Gjjason's Avatar
Default Which fuse/relay control the a/c compressor
DOES ANYONE KNOW WHICH FUSE/RELAY CONTROL THE A/C COMPRESSOR ?
2015 LEXUS NX200T
Old 06-02-20, 10:27 AM
n0v8or
n0v8or's Avatar
The NX air conditioner uses a "clutchless" compressor that operates continuously whenever the engine is running, so no relay or fused control wire is required.
The web page has a nice description of the technology:
http://www.cancore.net/wp-content/up...ompressors.pdf
The load the compressor places on the engine is varied by modulating the amount of refrigerant admitted. This is accomplished with a solenoid valve (built into the compressor) that pulses on and off according to the cooling demand. The solenoid valve is driven by a solid state device within the Electronic Climate Control Module (called "A/C amplifier" by Toyota).
Old 06-02-20, 11:56 AM
Gjjason
Gjjason's Avatar
Thank you for the information. Very detailed and good to know. When i visited mechanics they did not have a clue and say I need to replacement the "clutch"
Old 06-02-20, 02:06 PM
n0v8or
n0v8or's Avatar
If the compressor pulley center nut is not turning when the engine is running, the compressor may have seized. The compressor pulley is manufactured with 2 concentric parts joined by an array of "break-away" spines. Refer to attached training info from Toyota.
brook41 (06-02-20)
Old 06-02-20, 03:32 PM
ttsport15
ttsport15's Avatar
Wow Interesting
semar
11-11-15 07:24 PM
smesseng
Maintenance
06-09-14 01:55 PM
tuterz
Performance & Maintenance
05-28-08 11:29 PM
DRFT103
09-04-07 12:31 PM
nysupraman
SC- 1st Gen (1992-2000)
04-20-04 06:35 PM
Quick Reply: Which fuse/relay control the a/c compressor
