Water Dripping
Hey all my 2016 lexus nx200t starting dripping water whenever you start the vehicle, its pure water no odor no color and it leaks constantly if the vehicle is running. What could be the issue with this ?
Where is it dripping from? If it's dripping near the catalytic converter or the muffler, that's condensation and the exhaust system is doing it's job.
If it's not coming from the two items I just mentioned above, it's likely from your A/C system if you've turned it on... Then again, it's very unlikely it would start to condensate so quickly... If I was a betting man, I'd say it's the exhaust doing it's job.
If it's not coming from the two items I just mentioned above, it's likely from your A/C system if you've turned it on... Then again, it's very unlikely it would start to condensate so quickly... If I was a betting man, I'd say it's the exhaust doing it's job.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
