Electronic Dampening Aftermarket
So Ive been looking into getting some coilovers for the nx300 awd. Now I looked at the all the usual suspects and wanted to see if there are any universal Electronic Dampening Controllers. TEIN has theirs but I'm not sure if it's only compatible with there springs. There are others but I didn't see any that are universal. I just don't want to manually adjust the dampening every time i want to do something other than drive forward.
TEIN has an EDFC Active system that bolts controllers on to their Flex Z coilovers (not springs). You can fine tune vehicle behavior when braking, accelerating, and cornering at various speeds, with each corner having an independent damping setting. Needless to say, you can also set damping to fixed levels if you don't want it dynamically adjusting all the time.
The complete Pro system (motors, wireless modules, controller) and Flex Z coilovers would set you back around $2000 net of taxes.
Some more info for you: https://www.tein.com/products/edfc_active_pro.html
I can't answer your question on EDFC's compatibility with other coilover makes, sorry. There are too many variables involved (thread, adjuster depth, adjuster range in degrees, etc.)
The TEIN kit for the NX is VSQ92-C1AS3. They list it for the Harrier, which is mechanically identical to the 2015-present NX. This can be confirmed by Bilstein Japan's listing of the BSS6087J kit as being for both the NX and the Harrier. This isn't to be confused with the 2000s-era Harriers, which were RX twins.
Disregard...did more digging and yes it's compatible. Thanks again.
Blue98Gs3
12
03-26-14 05:28 PM
