Good evening everyone. This is my first time. Does anyone know what is the torque specs for the propeller shaft bolts. Also has anyone change the plugs at 64000KM or again 40,000 miles?
Welcome, Nice color, is that stock? . Plug removal is straightforward, remove plastic cover on top, I used a long extension 10” to 12”, just make sure use electrical tape to secure Socket. Make sure you number the wires 1-4 (left to right) facing motor, disconnecting the coils helps. Luckily the plugs are now aftermarket @11.34 each (Rockauto) NGK 91961Original OEM l wouldn’t use anything else.
On a side note anyone able to get to the drive shaft bolts at the front of the engine? i think I was able to get to 1 or 2 of them but the upper 2 were impossible to get to, extension wouldn't fit.
