Can Seat Memory Be Added?
I have a 2020 Lexus NX 300 Base. When shopping for the car, we discovered that the Base trim had all the options we wanted *except* seat memory. It didn't seem worth it to move up to the Luxury trim just for that one option. Now we're discovering that we really miss it (two very different-sized drivers). So the question is, can seat memory be added to a Base car and if so, what components are needed and what would it cost?
I haven't seen it documented here if anyone has done it, but it doesn't look like a simple add-on modification.
Are there any blank buttons/cut out on the door already?
ok, I snooped around, seems like it is "do-able" if you can source the parts (from other NX-ecu, wiring harness...) like this guy mentioned for an IS300:
Not an easy task......unless someone will chime in if they have done it.
