Programming the TPMS sensors failed.
7th Gear
Hello. He tries to add a new set of sensors to his nx300h, but receives the message "ID registration failed due to a communication error with the ECU while in initialization mode". I have a MINI VCI J2534 ver. 1.4.1 I even tried the option with connecting the TC and CG pins, in my case it doesn't work. Is it possible to add sensors (PMV-C210) at all with this cable?
7th Gear
Thanks for the message. My Mini VCI cable saves something when it comes to changing parameters, I changed, for example, window control and door lock options, and I changed it with this cable. On the other hand, TPMS programming certainly does not support it anymore and, as you say, you need another cable. Could you recommend any other cable at a reasonable price because the device you propose (Autel TS501 / 508) is too expensive.
7th Gear
I was looking for other tips on TPMS programming and I found suggestions for such equipment https://pl.aliexpress.com/item/40013...c00w4R28b&mp=1 . Maybe it can be used to install sensors?
F350
09-03-13 07:49 AM
