LOC install
LOC install
Hey all, has anyone installed a line out converter on their NX300?? I have the 8 speaker system, looking to get a little more bump. Should I splice in before or after the amp??
I have 2021 NX300 F sport
OGraham99 (07-14-21)
Here's part of the wiring diagram for speakers after the amplifier, should I tap into that lonely front speaker on the right of the image since there's no additional speakers connected to it like the rears? Or should that not matter?
I would not do that personally, you lose out if the song uses the balancer to add effects. I would tap both fronts speakers as those are full range. The OEM amp is in the worse place possible, since you're going to hate getting to it, might as well spend the extra time do two extra taps......
OGraham99 (07-19-21)
OGraham99 (07-20-21)
Lexuswiz (07-22-21)
@OGraham99 did you tap power from the car battery?
Do you have a picture on the OEM AMP?
I am thinking remove the spare tire and add a sub there.
End1ess (07-21-21)
OGraham99 (08-04-21)
HIGHLY recommend you to use some rubber amp mounting feet/spacers to lift that amp off the carpet. The RP amps from Skar are EXCELLENT budget amps, but they are still lower quality chinese amps that will get EXTREMELY hot if not mounted properly (like here in your case). All the cooling for the Skar RP amps are on the bottom of the amp. If not slightly raised, there's no way the heat can escape out of the amp, and you'll have a blazing hot amp, and eventually with send the amp into protect....and do that enough, you'll have a dead amp, sooner than later!
Btw, I've install THOUSANDS of these amps😎. Keep 40-50 of them in stock at all times. That mistake byouade is one 75% of customers I see make when installing themselves. Just take a few seconds and unscrew the amp and check out the cooling on the bottom of it! Good luck!!
V.
OGraham99 (07-28-21)
2Fast0
05-07-06 01:27 AM
