Rear brakes front brakes
Is it normal that i have 20% left on rear and 30% on front brakes? Shouldn't the front pads go before the rear ? Running about 50.000 km. On nx 300 2018.
geomike (04-12-22)
geomike (04-15-22)
I think the engineers are starting to make the rear brakes with less materials so they closer match the wear of the front pads. On our ES350 I didn't touch the rear brakes till well past 150K; whereas, on my sister's NX, I had to do the rear brakes shortly after I did the front, around 60K.
geomike (05-07-22)
The only thing I could think of is that although I LOVE the Adaptive Cruise Control (or whatever it might be called on the NX) I find that it tends to apply the brakes a tad more often than I would've (if the feature were disabled). Then again, I'm not sure if this would affect the rear AND the front ... probably !
geomike (05-19-22)
In my car the fronts went before the rears, I know that the stability control likes to use the rear brakes a lot, do you do lots of cornering etc? Btw, I just went for the Power Stop K4713-36 Front Z36 Truck & Tow Brake Kit since I tow and its been really nice so far. Originals lasted 55k miles. had 3mm left on the pads.
geomike (05-20-22)
Just changed all the brakes front and rear on my 2018 with 60,000 km and yes, the rears were down to 1-2 mm while the fronts were 2-3 mm left.
Opposite of every other vehicle I’ve owned, but then I never saw what the original pads had when new and I used aftermarket on the replacement pads and the pad material are the same depth. Guess I’ll find out next time at 120,000km.
geomike (07-22-22)
My last several cars (Audi, Lexus, Acura) all had rear brakes worn out quicker compare to front brakes. None of these cars had adaptive braking or other fancy options.
