Lexus nx oil change concern - does this oil look new or old?
I just had my oil change done at the dealership and when I checked this morning the oil seems dark, almost the same colour as the oil I previously had with 10,000 miles on it.
Should I be concerned? or is this how new lexus oil should look like?
Thanks
Thanks
As soon as I get my vehicle after service at the dealership, I pop the hood, take a good look around for any oil drips and spills in the engine area, pull the dipstick and check the level and oil condition.
One time I could tell the oil had obviously not been changed based on the level and color of used oil on the dipstick, plus the really dirty oil filter that had not been changed.
Dealership apologized and performed services, with the excuse that the paperwork was mishandled and the car jockeys thought it was completed already.
Yours definitely looks too dirty to be considered freshly changed.
NJLEXES (07-05-22)
Well, yet another reason why doing it yourself is BETTER.
I buy the oil at COSTCO - $30 for 6 quarts of Mobil-1 Synthetic. I buy the oil filters via the internet from some Lexus dealer clear across the country - usually about $5 apiece with oil plug gasket included.
Total cost for the oil change - $31 and not a lot of time.
This oil change is THE EASIEST, SIMPLEST of any vehicle I've ever owned. I only jacked up the car ONCE, the first time I did the service. Once I knew where everything was situated, I no longer need to even lift up the car. Just lay down on the ground, on top of a piece of cardboard, and do the job. SIMPLE!
the engine was changed 3 days ago, maybe 100miles since then
So the dealer called me today saying they checked the cameras and talked to the technician and said it was indeed changed. He said to come in so they can check it in person but indicated that the Lexus synthetic oil is darker then conventional oil … I don’t know how to prove if they are lying or not 🤷♂️
I changed my oil in early April (Castrol Edge full synthetic). This is what it looks like today. Appearance is identical to when I checked my oil ~3 months after my "complimentary" change by the Lexus dealer.
I am not buying any of the BS about turbochargers and direct injection prematurely darkening the oil.
The words "Lexus Oil" should have been an obvious clue to the truth. There is no such product as "Lexus Oil" (or Toyota Oil). Lexus does not make motor oil, nor do they make transmission fluid, windshield washer fluid, or engine coolant. I worked at a new car dealership while in college; all of these commodities are purchased in bulk from major manufacturers.
Jam008 (08-06-22)
The next thing they tell you will be Canadian oil is darker because the angle of the sun is lower than here in New England .
Ask them to show you the drilling rig at the far corner of their property.
HOWEVER...mistakes are made, corners are sometimes cut.
Here's a scenario...The young mechanic wanted to make a phone call, which lasted a bit longer than he had expected. When he returned to the vehicle he decided to NOT change the oil to recoup the 10 minutes he spent on the phone!
I must agree, I have owned forced induction cars for many years and all of them are hard on oil. That is the reason why European cars are so strict on their oil specs. Toyota oil is made by Exxon-Mobil which is pretty reputable. The color of oil does not indicate the effectiveness or the age of the oil, get a lab test if you want to be sure,
