2016 NX 200t, DRLs seem to work fine. When headlights are on, the right side low intensity marker light does not work. I believe the DRLs and marker lights are the same LEDs, just different intensity. Any help is appreciated.
It's time to replace it. Luckily there are several aftermarket replacements to choose from that can save you $$$. DIY and save even more $$$. Rockauto.com is my goto place.
Is there somewhere to find a wiring diagram for the DRL circuit?
Are the marker lights wired into the headlights or do both the DRLs and marker lights come from the ECU?
Maybe I can check the connector pins for voltage.
Thank you! This is exactly what I need. Not sure I have the expertise to fix it but I’m sure I can eliminate some stuff and hopefully find the problem. Thanks again.
