NX450h+ - Charge Schedule Not Stopping as Expected
7th Gear
Hi folks,
First time post, but long time reader. I am having the hardest time with what I believe should be a simple process. I am trying to charge my car within a set time window, for example, 12am to 6am.
Any thoughts?
- Rick
- Is it possible to charge during a defined window of time like the example stated above?
- If yes, how do you do it?
- I navigate to the Charging Schedule using the car's center display
- I set a Start Charge Time of 12am
- I set a Departure Time of 6am
- I see this as the only way to provide a scheduled end to a charge
Any thoughts?
- Rick
Are you charging on a level 1 charger or level 2? 12am to 6am is 6 hours of charging. If you are on level 1 it will definitely go beyond 6am as it does take 12 hours to charge. If you have a 3.3kW charger, that is about 5 hours to fully charge and it should fit the timeframe.
If you have the 6.6kw, it will definitely fit the timeframe with a level 2 charger.
When it's 6am is it slowly charging to 100%? I noticed mine would take like an hour to finish the last few %age - even if it says 100% already.
I have found the charging is quick accurate with my NX and I typically set it to departure time. I would say you should set your departure time to 5:45am and it should be done, but if your charging time requires more than 6 hours, it will start earlier.
SgtLip (04-08-23)
7th Gear
I am using a Level 1 charger for the time being, but will be upgrading to 220V and a Level 2 charger at the end of the month. This should resolve most of my problem since I'll be able to do a full charge with my 6.6kwh onboard charger. I'll also be installing the Juicebox 40 Amp unit which is supposed to come with it's own charging scheduler.
Until then, and to scratch this mental itch of mine, I still want to know if the NX450h+ or it's app has the ability to charge in a defined period of time vs. the car determining when to start or stop.
(and to answer your question, I'm still charging well after 6am when starting from zero charge and 12am)
- Rick
- Rick
- Rick
- Rick
SgtLip (04-08-23)
dnasians
05-09-24 11:41 AM
ModInJapan
CL Vendor Products for 4RX
09-01-21 06:45 AM
ModInJapan
CL Vendor Products for 4LS
01-29-19 10:32 AM
dendenyc
12-10-18 07:29 PM
ModInJapan
LS - 5th Gen (2018-present)
07-18-18 01:07 PM
