Tow Hook NX 2022
Just looked at the Lug Bolt and the thread on it is finer. The Tow Pin is a coarse thread.
I have a 23 NX 450H+ Base. Here are the photos of the Tow Pin I received with my vehicle.
Note: Made comments under each photo.
This is the Tow Pin received.
It is a total of 10" long.
The Thickness of the Tow Pin is 1".
The Tow Pin Threads are 3/4". I do not know the thread number.
Hope this helps.
Hope this helps.
I have a 2024 NX350 base and have been looking for the tow hook license plate mount as well. Anyone have any luck finding one that fits? I asked ijdmtoy awhile ago and they said they don't have any that fits.
I don't know for sure but I assume there are only a handful of thread sizes for tow hook right? If so, there should be one made with a matching thread size that works right?
You mean you want something like this -> https://www.ebay.com/itm/364169847798
I received the mount few days ago but didn't try it yet. I'm thinking if the yow hook cover is removed, would it cause the inside to rust since it's exposed to rain, snow, car wash? I as thinking if I can drill a hole to fit the mount's post thru it so less water gets in but seems hard to drill on the right spot.
I received the mount few days ago but didn't try it yet. I'm thinking if the tow hook cover is removed, would it cause the inside to rust since it's exposed to rain, snow, car wash? I was thinking if I can drill a hole to fit the mount's post thru it so less water gets in but seems hard to drill on the right spot.
https://www.lexuspartsdirect.ca/p/Le...196142060.html
Here you go. This is straight from Lexus of Canada $49.60 CDN Your dealer can use this part number it's universal.
