Center console lit rattling
I have a 2024 NX 350 and noticed that the center console lid rattles while driving. It seems the tolerances are a bit too big. Has anyone had this problem and had a fix?
Mine doesn't rattle, but I was kind of surprised it doesn't because the dual lock mechanism on each side doesn't seem particularly tight fitting (which is good I guess, not hard to open from either side). But what I did notice is that at the back underside of the cover there is a rectangular opening that fits over the dual direction hinge. If you look up inside this opening there should be some kind or rubber or felt pieces (if you've ever bought electronics that can be both mounted or just placed on a table, they sometimes come with 4 little rubber feet you can stick on the device, the ones in the cover kind of look like that). I think these are placed to prevent rattling. See if they are present, maybe add your own slightly thicker ones if necessary.
The following 3 users liked this post by Droid13:
pokerbud81
09-24-19 03:09 PM
