Can the Blind Spot Monitor issue audible signal?
Also...the yellow blind spot warning light in the mirrors should be larger.... A triangle or strobbing/flashing light
On that note though, a RAV4 nearly ran into me a week ago even if I could see his BSM (clearly not BSW) flashing in his left side mirror. 💁♂️🙁
GV70 has...
Red blinking/flashing light in the dash panel. A audible warning tone. Flashing/Blinking light in side mirrors. And something I learned at test drive... When the turn signal is on the side camera shows the lanes you want to change into.
Kodiak412 (08-01-23)
My dad bought a new Hyundai Sante Fe and it does all those things too. Plus, it gives the BLIS (Blind Spot) info in the HUD. The technology is there and has been around for a little while too. Seeing that it is a safety feature and not just a luxury feature it should be expanded upon by all manufacturers.
Sounds (08-01-23)
I think that is why test driving before you buy is the most important thing. I agree that it could be a setting for someone to turn on and off. I would turn it off as it's annoying as hell to keep on beeping. The BSM is to assist my lane change and not to rely on for a lane change. I still check my blind spot before changing. It's obvious they can do it since the safety exit assist beeps and speaks when it doesn't let you exit. I guess it's a deal breaker depending on what type of driver you are.
romer (08-01-23)
Totally agree, but when driving downtown it will keep on beeping as people when you are in tight areas. Again, this should be all configurable in the world of personalization. But Lexus/Toyota is too conservative.
I previously owned a RAV4 Prime, and some folks on that online forum complained about being annoyed by false positives, i.e., getting beeped when there was nothing in the blind spot. They preferred the flashing light instead of a beep. Of course, I thought that was a nonsensical way of design. Why include a flaky design and mitigate the flakiness of that design by making it easy for the driver to ignore the warning? That's bad engineering. Either the design should be robust and trustworthy, or it should be omitted entirely.
The problem with the blinking light is that it's far too easy to ignore, especially since the light already gets lit whenever a car passes on the side. If the engineers wanted to avoid the beep, they should have at least made the visual warning easy to see, especially for a driver that is executing a lane change and not staring at the side mirror. For example, the entire perimeter of the mirror could flash rapidly, especially with a markedly different color than the small amber light that is too easy to ignore.
AtomicLexus (08-04-23)
But every single other safety feature is accompanied by additional non-visual feedback. The NX LSS 3.0 is like an orchestra except for this single feature.
