Hey Siri Not working
2nd gear
Has anyone had issues with Hey Siri not working in a 2022 350h. We've got 4 phones loaded into car profiles.. and none of them will work. Pressing the steering wheel button will engage Siri in CarPlay, and Hey Lexus spoken commands also work. Just not Hey Siri...
Our phones all work with Hey Siri spoken commands in the house, but as soon as a handset connects via CarPlay in the 350h, the Hey Siri command just doesn't operate. As an example I ask Siri to close our garage door through a HomeKit app as I am in the car, but if I wait too long after starting the vehicle, then CarPlay boots up and the Hey Siri IOS screen on my phone just shuts down
I've trawled through all setting options in IOS on my iphone, but seems strange that all 4 of our phones phones exhibit the same behaviour.
Thanks, Adam
Thanks, Adam
Thanks, Adam
Thanks, Adam
Northside Lexus's YouTube tutorial demonstrates this here
2nd gear
Hey Siri will only work if you are on the CarPlay screen on the infotainment Otherwise you have to push and hold the voice command button on the steering wheel
YouTube
YouTube
It used to work for me, but it currently doesn't. I complained to the dealer about it but they said it's normal, which is incorrect. It's either an IOS bug or a 21MM bug, or both.
Thanks, Adam
Thanks, Adam
I have had the exact same issue as you did on my 2022 Lexus nx350h. I have skimmed through the internet looking for solutions. Finally found the solution. You have to lower the system voice volume to the second lowest setting. It sucks bc you can hardly hear Siri when driving but at least you can send out texts and it can read it back to you without it saying what do you want or rant on endlessly.
I'm not sure how this setting is saved or if there is a default that I'm unaware of, but on my '22 350h after I say 'Hey Siri' I can see the microphone appear on my HUD and it turns green color plus the little Siri icon shows up on touch screen. If I'm not hearing anything back from Siri I quickly go to the physical volume button and turn it up. I think you can only adjust the Siri voice volume setting while it's talking or active. Anyways if I miss it by getting to the volume **** too slowly I just activate something like Maps on my phone and as it starts to call out instructions I turn up the volume. For some reason it's always turned way down or silent when I first get into my '22 350h. I don't know if there is a phone setting I can set for this but this is my workaround for it. After I've turned it up that volume level is used for all Siri actions such as reciting texts, map guidance instructions etc. I hope this helps out. If there are multiple phones active (I never have more than one so I can't confirm) you may have to repeat this for each phone possibly, I don't know.
