NX450H+ Wobbly Ride
My 2023 nx350 with 18 inch rims has a wobble too. I took it to the dealer a few months back and they said they couldn't replicate what I was talking about and thought it's just the road surface. They said since these are run flat tires with harder side walls that they don't flex and absorb road imperfections very well so what I'm feeling are the road surface. I told them no it's not, I told them I could get a wobble when I'm making a right turn at a light or stop light and giving it lite to medium lite throttle on different roads. I also told them that I feel it more in like 2 and 3 gear when I'm in slow rolling moving traffic between 20-35 mphs. I talked to the head tech and he said he checked the tires, suspension, and axles and saw nothing. He said he never heard or seen any complaints about wobbles on this car and when i could constantly replicate the wobble they'll look deeper into it but they highly believe it's the run flare tired.
Curious if anyone has changed their tires from run-flats to regular and what changes they noticed in wobble. I’ve read about results in a less noisy and harsh ride which isn’t an issue for me. Just the random wobble.
Billst (10-10-23)
For those that have ‘the wobble’, curious if you’ve taken out a Lexus service person with you on a drive and pointed out to them exactly the events your referring to?
Is it reproducible at a given location? If so ask to test drive a new one on the lot and see if it behaves the same way.
Bouncy Rear End on '23 NX 450h+ F Sport with AVS & 20" wheels
Just acquired this vehicle with <10K miles. Love the seats, pickup, looks, etc., but surprised that the rear wobbles/bounces when driving over even small bumps or road imperfections. It happens even at city speeds and gets worse at highway speeds. Found this forum and read everyone's comments. Has anyone found a way to improve it via non-run flats, smaller wheels, wheel alignment, etc.? Thanks.
@tundotcom , just wondering if you had this problem before you installed the trd-door stabilizers and did the stabilizers fix some of the problem o:
https://www.clublexus.com/forums/nx-...abilizers.html
Different Tire inflation?
Just thinking out loud. Other than suspension or wheel balance, different tire inflation rates could contribute to the wobble you're experiencing. See if you can check and adjust tire pressures on all the four tires to the recommended levels could help alleviate the issue.
