winter wheel flat surface and oem lug bolts
1st Gear
hey all,
I was installing my older oem lexus rims with winter tires but came to find out my 2022 lexus nx 350 uses radius wheel bolts instead of lug nuts. The bolts are a little too short and sphere shaped to fit my winter wheel that has a flat surface.
So far, I've only been able to find radius and tapered style lug bolts and I'm not entirely sure it'd be safe on a wheel with a flat surface. Does anyone know which places or companies sell flat surface lug bolts? I'm looking for flat surface M14x1.5 with at least 35mm thread length.
Thank you!
Thank you!
hey all,
Thank you!
Thank you!
80307 1 WCA 14X1.5 BLTSD 25MM ZN 5L
NRM HDWARE LUG BOLT KIT WZ25014CB
Tire store, amazon, ebay, your local lexus dealer...
So I contacted the manufacturer and they said those are just acorn type lug bolts so I believe tapered. He said they don’t have flat lug bolts unfortunately.
i saw Land Rover has certain flat lug bolts that might fit but it’s pretty expensive and I mostly only found them in the UK. Makes me want to give up unfortunately…
