While in adaptive cruise how do you reset
When you are accelerating past the limit you have it set for and the screen says to change to the new higher speed hit the cruise control button and there is a + there also but that turns it off and then I have to hit it again to turn it back on and I’m assuming I’m doing it wrong.
important to note I have the heads up display
LiBeRtAs (11-01-23)
If you are saying all you do is hit that button that’s pictured in the other reply here and nothing else just hitting it once turns cruise off for me.
But now I am realizing that I am not supposed to hit that button on the steering wheel to reset but to hit it on the heads up display.
thanks to both of you I will give it a try.
Thanks for answering, if I’m already in adaptive cruise and I hit that button once it turns adaptive cruise off.
Hit that button on the heads up display screen not the physical button on the physical steering wheel is what I assume you mean. To turn it on you hit that button and turn it off but to do what we are talking about you have to do it on the screen, I have never set the adaptive cruise using the heads up display I’ve always used the wheel
romer (11-02-23)
LiBeRtAs (11-05-23)
LiBeRtAs (11-05-23)
LiBeRtAs
NX - 2nd Gen (2022-current)
07-22-23 06:30 PM
