key detected in car
I've had NX hybrid for around month. I mostly use wallet card, but noticed with key fob same happens. The issue is when i get out of car, key in pocket, about 50% of the time i can't lock car via door handle due to message on dash 'key detected in car' and constant beep. I can lock via app successfully. Or I can wait an "X" amount of time (haven't tested enough to know for sure), then somethings clears, then i can touch door handle to lock.
Anyone else, or someone know solution? Thanks
yes on iphone, however the iphone is never left in car......and whenever I have used digital key to operate car, i must always open app because i don't enable background services.
The only time I've seen this happen is when I have the digital key on and the car still detects the phone in the car. Next time try to take your phone away from the car and try to lock. See if that works or not.
LiBeRtAs
NX - 2nd Gen (2022-current)
14
06-02-22 10:14 AM
Jerry0249
01-23-19 08:33 AM
