Anyone Switched Out Their 12 Volt Battery For AGM?
I have a 350h , live in a warm climate, work from home 3/5 days per week and drive about 200 miles per month, have a dashcam with parking mode hardwired to cutoff at 12.2v.
Zero issues so far after 5 months with the 12v battery. Parasitic drain on yours? Did the dealer offer to replace or monitor the battery for issues?
a2023LC500 (01-13-24)
Wished all it did when on ACC after 20 mins is switch off as it states in the manual. But it will definitely discharge the entire battery if it’s already low and you sit in park with hybrid system off. Learned the hard way. Never had a vehicle do this on me before so caught me by surprise. I now leave the NX on ready mode when parked and messing with the computer. No reason to switch it to ACC mode.
You would think a $60+K luxury car would come with a AGM battery. There is a thread about parasitic drain but I suspect is a partially a design flaw of the DC-DC inverter. I would think if you were to Plug-In to recharge the traction battery that would also charge the 12V but that does not seem to be true.
my 2 cents
my 2 cents
You would think that was the case, but charging the traction isn’t enough to charge the 12 volt. In fact, if you leave the charge cord plugged in after the traction battery is topped off, the computer monitoring the cord will draw down power from the 12 volt until you unplug it. So you should unplug after the traction battery is charged up or you could kill the 12 volt. (At least the low mileage folks more susceptible to dead battery issues)
I am new to the Hybrid and am going to have an installation done soon, what instructions should I give the installer to prevent having any 12V issues?
How can the doors be left open for a few hours so as not to drain the 12V battery?
Under what conditions would I need to activate the "ACC" mode ?
So, is the message here to NEVER start or press the Power button unless I hit the brake pedal first?
Thanks for your response
Anyone here use this brand?
https://www.odysseybattery.com/produ...attery-48-720/
LeX2K (01-10-24)
@LeX2K I can vouch for Odyssey batteries as I have PC1200MJT installed in my non Lexus car. For my aftermarket air suspension along with two decent size air compressors setup with air management the Odyssey batteries powers up great! Odyssey batteries fires up no problem in the WA mild cold (gets as low as 20 degrees F) But the problem is, you can't buy a direct OEM fit Odyssey battery, you need to measure out OEM battery tray or battery compartment and see what Odyssey battery can fit. Overall would recommend Odyssey batteries! I would upgrade in my RX 500h but the wife said I can't touch the RX but she did request for JDM window visors for the RX buhaha!
Well thus far in each cold spell over 2 winters, the 12V battery has failed and this time will require replacement again (this will be 12V battery #3). I'm probably going to buy one at Costco this time so I'll have a spare after the dealership replaces the current one. Apparently that will require Lexus roadside assistance to tow it 300+ kilometres to the nearest dealership. So be it. If a vehicle can't be expected to start in cold weather without the 12V battery being trickle-charged constantly every time it's parked, then Lexus deserves their extreme roadside assistance costs. Unfortunately it's more than a week wait for a tow currently. At least our NX is at home and we also have a second vehicle that starts every time, and typically isn't even plugged in.
I am running an AGM battery in my winter car it's fine. I feel like in super cold weather it doesn't perform quite as well as conventional but that won't be an issue for you. They are not good in hot climates. Next time I will buy a regular lead acid don't feel the extra cost was worth it.
Sorry to hear that, crazy! But they are replacing the battery? So they say it’s a battery problem? Down here in the states the dealers say there’s nothing wrong with the battery, just how Toyota designed the recharge mechanism so that people who only take short trips consistently drain the 12 volt until it dies. But in your case they’ve said your batteries have been defective?
It's also 42 below Celsius and in my experience, lead acid batteries are irrevocably damaged with so little voltage in these temperatures. The question becomes one of how was the voltage allowed to drop so low? My wife started the car in EV mode this morning but a few seconds later when the gas engine tried to start, everything went dead, dead, dead. Again.
