New software update
#31
It should show the update again. I started the download on mine, turned the car off and then an hour later turned it back on and it continued to download and then eventually install.
#33
#34
Same here, works as before with very few issues. This morning upon leaving my garage it gave me an AA wireless connection failed error (which I have seen 3 or 4 times over the last year), but tapping Retry it connected up in about 5 seconds after that and was solid the rest of the trip, exactly as I found the few times before when I've seen this msg. Prior to the update on rare occasions (again, maybe 3 times over the last year) I've had AA drop in the middle of the drive and actually required me to turn AA functionality back on within the Infotainment settings before it would reconnect (which it would always do and generally be reliable afterwards). I have not had AA drop in the middle of a drive so far, but its only been a few days since the update.
Lately I've been playing with an AA enabled weather radar mapping app (so I can see rain and snow events as they move thru the area while I'm driving). Its a beta version and has crashed out within AA, but AA itself stays running on the NX screen (other AA apps continue to work too) and the app self recovers after 30 seconds, so more than likely an app issue, not AA or NX one.
#35
#36
#37
![Angry](https://www.clublexus.com/forums/images/icons/icon8.gif)
Just got the update today on my 2022 NX350. Now my multi-media screen is blank out. Using the Lexus app to start up the vehicle would see the screen keep flicking. The reverse support is still working tho but just not any other function (cannot change AC and seat heating) Contacted the services center and was told to bring it to the dealership.
#41
After experimenting with the new AWD screen, I've noticed some things. It definitely seems (to me at least) snappier in response time. It does more clearly show the front wheel drive bias (which is not unexpected), but a couple of interesting things. When accelerating with modest briskness (enough to turn the drive blocks purple, say... 4 blocks) I notice both front and rear wheels show the same number of blocks, but with each gear change the rear wheels would go to 0 blocks then back to the 4 purple drive blocks while the front stays at 4 drive blocks thru a gear change. Curious, I wonder if that is really what's happening, that my car is releasing the rear diff clutch in between gears or if this is some artifact from the animation logic. I've also been able to, although not at all common, get the screen to show more drive power from the rear than the front when stepping on the gas in some situations. I remain curious if this new screen is actually providing genuine new hints to powertrain operation...
#42
So did this software update retune/recalibrate the engine?
#43
![Talking](https://www.clublexus.com/forums/images/icons/icon10.gif)
YMMV ( depending on flux level)
MidCow3
I installed and looked bleh
#44
This update broke wired android auto for me. I'm not a fan of wireless AA because it chews through my phone battery and sometimes I don't want to connect to AA.
After the update, wired AA refuses to connect. Wireless A works the same as before.
