Ask any question , nothing is stupid
#46
[QUOTE=Stedman;11777743]
- Program your seat and settings to #1. Then program the seat extended all the way back with the steering wheel all the way up to #2. This way, when you are ready to exit, press #2 when in park and it will do the same thing. Then when you get back into the car, press #1 and you're on your way!
#47
It should be possible, I drive with my seat all the way back to the max, so it does not move when I exit, but every time I turn off the car, the steering wheel retracts all the way up and into the dash. Just look through the settings, it is probably ON and OFF switch, where everything moves back to the limits whenever you trying to exit and easy exit enabled.
#48
Rotating KeyFobs
Hello everyone, In order to avoid having to have the key fob reset or otherwise dealt with due to it sitting inactive and perhaps draining the battery, how are you guys making sure to use both of them? Does anyone rotate their key fobs approximately every six months?
#49
YMMV,
MidCow3
#50
Great
