Type of Gasoline?
The Natural Resources of Canada has stated the 450h+ is electric + premium fuel.
https://fcr-ccc.nrcan-rncan.gc.ca/en...leReport/26577
Premium required(recommended) , 87 regular works fine
So, you can sometimes get away with using regular in a pinch and not see much effect from it, but it's not a good idea to make this a routine. If you have any uncertainty on the matter, check your owner's manual; if it states that the vehicle requires premium, take it seriously. Trying to pinch pennies at the pump by opting for regular when your car really needs premium could come back to bite you when your car is in the shop for a condition your warranty may not cover. It is very hard to determine what octane of gas has been used and to say it may void warranty is pure fear mongering.
YMMV,
Midcow2
The manual recently given on the Canadian Lexus website gives all the gasoline requirements and recommendations.
I know it says that the 350h can use octane rating 87 without risk of damaging the engine. I did not check for the others, though I assume the same.
Another reason to use Regular gasoline RAV4 Prime uses regular
The 2022 Toyota RAV4 Prime has the exact same engine as the 2022 NX 450h and it recommends: 87 ( Research Octane 91) or higher. 87 is regular gas.
I ran 87 on my RX for years and never noticed a performance hit. The 350h NX though doesn't have the same HP so it may be noticeable. I will start with 87 when my ordered 350h ever gets delivered. The usual sentiment is there is not much difference.
From the 350h manual:
Recommended to use premium unleaded gasoline with octane rating of 91 (Re- search OctaneNumber of 96) or higher for optimum engine performance. You may use unleaded gasoline with octane rating as low as 87 (Research Octane Number of 91). In this case, engine performance may be decreased.
The following 3 users liked this post by midcow3:
bump up to Top
Another great discussion about the grade of gasoline which a recent discussion thread on premium gas chose to ignore.
Use regular and save money. Apply your saving to more frequent oil and filter changes.
YMMV,
MidCow3
YMMV,
MidCow3
High compression low octane = destructive detonation = broken engine = $$$$.
Computers are fast ( Note; car manufactures use very slow computers ) but the pinging you don't hear are the ones that destroy the engine.
Wow, look at the pretty holes in the pistons, destroyed ring lands, melted spark plugs, fried valves and the list goes on............
But, but I saved a fortune running regular!
The following 2 users liked this post by Tinkertech:
romer (11-30-23),
SeismicGuy (11-30-23)
