Dashboard rattles??
#61
i was at Lexus on the Park recently and the service experience was much more pleasant than purchasing (not saying purchasing was bad) and best i've received compared with BMW/MB/Porsche and improved from my last time with lexus (granted it was like many years ago and it was already very good before).
they were also very diligent in making sure that i'm able to give them a perfect 10 on the lexus survey that i'll get from dropping off car/workorder/pickup etc... when did lexus add in corporate survey for servicing?
After that service - my dashboard has never rattled again (the other rattle issues... well, are still a work in progress)
#62
My dealer looked at it but couldn't pinpoint where it was coming from. The tech said they dislike taking things apart since this could create other issues. He stated that once there are 1,000 complaints, it goes to another level where it would lead to a recall. If it is happening to you, please check it in with the dealer so they will have the record.
#63
If the noise is not discernable and repeatable, then It is more difficult to diagnose. Every time the noise occurs you have to document all the environmental events leading you to the noise and look for some commonality.
Yes, the tech dislikes taking things apart because it is more work on his/her part. But if you can't easily repeat the issue then this is the best method.
All problems can be solved; some dealerships are either lazy or incompetent. Sometimes an escalation plan must be invoked.
YMMV,
MidCow3
#64
It's not your fault that your brand new car has rattles and any dealer should fix them.
Lexus's viewpoint (at least in Canada) is the same.
#65
Just got my car back after leaving it at my dealer for 7h and here's what's showed on my invoice ($0 to pay of cause)
M-D'O------------------------------------------------------------------------------
#A 1 19LEZZ13-B DASH HRES : TECH(S):725 GARANTIE
CONDITION: AS PER GUEST HE HEARS A VIBRATION COMING FROM THE FRONT
DASH WHILE DRIVING
NOTE: AT ANY SPEED - GUEST THINKS IT MAY BE COMING FROM
DASH/VENTS
CAUSE: CONFIRMED NOISE
CORRECTION: INSOLATION ADDED TO DASH
PIECES-----QTE---PD-NUMERO---------------DESCRIPTION---------PRIX LISTE-PRIX UNITE-
1 08231-00810-WA OBS GARANTIE
TOTAL - PCES 0.00
#ACT 1 TOTAL ------------------------------------------------------------
#ACT 1 PREFIXE JOURNAL LECS #ACT 1 TOTAL 0.00
#ACT 2 FRAIS ---------------------------------------------------------------------------------
#A 2 19LEZZ06 DOOR(S) HRES : TECH(S):725 GARANTIE
CONDITION: VIBRATION COMING FROM THE REAR RIGHT DOOR WHILE DRIVING -
(INTERMITENT) PLS VERIFY
CORRECTION: RE AND RE DOOR PANEL TO INSOLATE. ROAD TEST AND NOISE WAS NO
HEARD
TOTAL - PCES 0.00
#ACT 2 TOTAL ------------------------------------------------------------
#ACT 2 PREFIXE JOURNAL LECS #ACT 2 TOTAL 0.00
#ACT 3 FRAIS ---------------------------------------------------------------------------------
#A 3 03LEZ PNEUS ET ROUES HRES : 0.01 TECH(S):725 0.00
CONDITION: AS PET GUEST - THERE IS A WISLE NOISE COMING FROM THE TIRES
WHILE DRIVING AT SLOW SPEED AND GOES AWAY WHEN ACCELERATING
CORRECTION: HYBRID NOISE WHEN COASTING
#ACT 3 TOTAL ------------------------------------------------------------
For the #3 cause, I'm not sure they catch the noise, but I will make record so next time they can made a proper troubleshooting.
As for the noise, I've not driving my NX that much to be sure, but suddenly it's became quieter LoL
DASH WHILE DRIVING
DASH/VENTS
TOTAL - PCES 0.00
HEARD
TOTAL - PCES 0.00
LexusRX350L1 (10-25-23)
#66
@alvinklee, If you want my Dealer info, tell him to call : Spinelli Lexus Pointe-Claire ![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
Drove quite a bit with it after the fix and it's now totally silence of those annoying vibration noise.
I still hear sometime the "squirt" noise from the engine but only if I roll my windows down and drive with the gaz engine at low speed.
Good luck to you to get it fix, hope you can use my invoice, if needed, I can sent it to you via PDF format.
#67
MTL2022 (08-29-22)
#68
I have a few creaks and rattles that I went to the dealership for. There’s one on each side of the car and one coming from the dashboard.
The dealer thinks they were able to find the source for the one on the passenger side but they accidentally damaged the speaker grille area of the panel. So I have to wait for that to be replaced.
They think that the rattle coming from the driver side was caused by the rear seats not being locked in place, but I still hear the creaks after making sure it was locked in place.
Now I have to decide whether or not I should leave the car with the dealer for 3 days to find the rattle in the dashboard. They said that they don’t really recommend doing that as it might introduce new rattles the vehicle. Any advice from the group?
#69
I'd leave the car with them, and if they cause more issues - ask them to fix those too. If they won't - reach out to Lexus directly. My dealer has been proactive with fixing EVERYTHING and has gone above and beyond. They insist that this is the Lexus way, not a "we don't fix small issues" approach.
The following 3 users liked this post by Ihave1cat:
#70
I have to say, knock on wood, that my 1-month old 450h+ is completely solid with no rattles at all, including even the driver side mirror which I paid particular attention to after seeing the issue mentioned a lot here. The only thing I've noticed that bugged me a little was a low whirring sound I kept noticing at low speed... then it dawned on me... that's the intentional sound it makes when driving around on battery power to warn pedestrians...
#71
I got my suv back after couple weeks. I think the rattle is gone from the driver side at least for now FINALLY. I am not sure if I am being picky at this point on anything else after driving the ES350H loaner. Wow, I think that probably has one of the most quietest luxurious interior. I noticed that the newer NX is not as luxurious.
Though, I am wondering if there is a rattle potential near the seatbelt adjuster actually. It comes and goes randomly, though its not as much of an issue as the dashboard rattle.
#72
There’s a few mentions of rattles coming from the dashboard. How common is that?
I am taking delivery shortly of the NX450h. Rattles/creaks from dash, hatch, doors, windows, seats are not acceptable to me. They rarely have a happy ending and they greatly interfere with my enjoyment of the ride….for me. I know that if I go to the RX, it will be rattle free. Maybe that’s the route I should go?
#75
I have some weird ticking/rattling noise comming from rear passenger area (probably the door panel), anybody experienced similar issues?any idea?
video of the issue:
video of the issue:
