Part numbers for 2022 NX Models
I am looking for part numbers for some accessories like all weather floor mats, cargo mat.
When I contacted my dealer, they provided below:
Anyone has any suggestions?
- All Weather Cargo Mat (1Pc): PT908-78220-02
- All Weather Floor Mat (3 Pcs): PT908-78222-02
Got the activity mount hitch installed by Lexus of Willow Grove today. PN is PT974-78220. $265 for the part and labor was $334... So they did it for $599. It's the 1 1/4" one that apparently you can't tow with this, but that's fine I just want to put a Thule rack on it.
Last edited by miggyt1; 01-31-22 at 04:07 PM. Reason: I was wrong about something so I wanted to edit it so nobody makes a mistake when buying this.
gcskoor (03-03-22)
I believe it is a transmission cooling package.
From the online brochure:
2,000-lb towing capacity42 (Tow hitch available Spring 2022)
42. Before towing, confirm your vehicle and trailer are compatible, hooked up properly and you have any necessary additional equipment. If gross trailer weight is above 5,000 lb (2,268 kg), it is necessary to use a weight-distributing hitch with sufficient capacity. Do not exceed any Weight Ratings and follow all instructions and cautions from your trailer-hitch manufacturer and vehicle Owner’s Manual. The maximum amount you can tow depends on the total weight of any cargo, occupants and available equipment. See Owner’s Manual for limitations.
