Why did Lexus choose a slow charger
The new 450H+ Plug-in hybrid has an onboard 6.6kW charger which is supposed to take about ~3 hours to fully charge the 18kW battery/36 Miles. I am curious, why didn't Lexus choose more faster charger or battery technology that could have charge the full system within hour or so? Pardon my ignorance about the battery technology, but when Teslas can be fully charged (~70kW battery/310 Miles) within an hour (of course faster charger), wouldn't be great if Lexus gave us an option for more faster EV charging option? Or was there any specific technology limitations?
Doesn’t the Tesla use a different system like DC power. Where the Lexus NX uses the same RAV4 battery system that’s been out 5 years?
Also to get those quick charge times on the Tesla. Don’t you need to use one of the Super charger stations? How many homes have those available?
Since you have a gas engine in the 450h range anxiety should not be an issue. Thus less need for fast charging. Whereas in a Tesla you could be stuck for hours without a faster charger on a longer trip.
3.3kwh or 6.6kwh chargers are very common on PHEVs. I don’t think any PHEV uses anything faster. The battery pack is much smaller in comparison to an EV. It doesn’t need the complexity and cost associated with a higher speed chargers. In day to day use, the 2-4 hour charge times is plenty quick enough. Even less time if the battery isn’t empty. I’ve found that even the slow 120v power outlet charger to work fine for me. Just plug it in when I get home and it’s full the next morning.
scooky (05-20-22)
Lexus is focused on durability, Tesla will cover the model 3 battery for 8 years and 100,000 miles (up to 120K for Long Range) - https://www.tesla.com/support/vehicle-warranty - Lexus covers the batteries for 10 years and 150K. Fast charging is a higher stress on batteries than slow charging - I suspect that is why the warranty is longer - Lexus tends to be more focused on durability - it is part of their brand identity. Tesla will only warranty the battery if less then 70% charging - Lexus doesn't specify,
It slowly charges the main battery - as others have said - like any other Hybrid - but the charge times are slow - about the same as when plugged into 110 V outlet.
Give them room for a "New & Improved" model later!
adb04 (01-24-22)
I can attest that the regenerative brakes can charge pretty fast. Much faster than the 110V wall charger and closer to the fast charging. The reason it doesn't feel fast is because there are usually an equal number of braking/charge times as acceleration/depletion times. However, I was able to verify that regenerative charging is fast because I recently went on a trip to a mountain (Big Bear). On the way down from the mountain, I was initially completely depleted and was able to charge up to about 12 miles in a little over 30 minutes of continuous downhill driving. Once at the bottom of the mountain, I had a flat drive and verified the approximate distance in EV only mode.
Hope that helps
CdO (08-18-22)
I just placed my order for a 450h+ today! In order to take advantage of the government rebates in my area, I was restricted to the Ultra Premium trim level, which I think is what I would selected regardless.
So, I have been researching the charging... and reading these posts has been very helpful.
So to be clear,
Thank you
So to be clear,
- I can use the included charge cable connected to a standard 120v outlet to charge the battery in ~11h
- I can use the EVDOUBLER (or similar) to connect the included charge cable to a 240v outlet and charge the battery in ~6h
- In order to achieve the ~2h charge time, I would have to purchase and install a dedicated Level 2 charger connected to the 240v outlet (recommeneded brands are Lectron, ChargePoint, Schimacher)
Thank you
It’s super helpful.
do you find it practical or realistic to buy NX 450+ for those who do not have a garage to charge at home every night?I’m trying to see if relying on regenerative brakes to charge EV battery is realistic. Did you try fast charging at public charging station?
I have the NX450h+.
Hope that helps
Hope that helps
It’s super helpful.
