NX350h Auto-Dimming Side Mirrors
Can anyone with a 350h confirm that both side mirrors are supposed to be auto-dimming? My left one is, but my right definitely is not (no lines around the perimeter).
The Exterior Features section of the spec sheet the dealer email me includes the following:
"EXTERIOR FEATURES Bi-LED-headlamps and daytime running lights, Roof-rails Rain-sensing-windshield wipers, Power-open/close rear door, Auto-dimming-heated outside mirrors with auto tilt-down in reverse, Blade-Taillamp, Power-tilt-and-slide moonroof, 20-in-20-spoke alloy wheels with Silver finish"
This is for a 350h with the Luxury package.
Our NX 350h does not have the luxury package. The outside mirrors auto tilt w/reverse, heated and power fold.
But the passenger mirror is not auto dimming.
Our 2014 IS and all the ES we’ve had both outside mirrors auto dim.
Honestly, I don’t think it’s a deal breaker and on the right side it probably doesn’t make a huge difference.
It would be interesting to know the reasoning behind not having it auto dimming.
I haven't received my 350h yet so I really don't know. The information i gave was from the spec sheet my dealer sent. The info concerning the mirrors was list under "Features". I believe these listed features are standard for 350s but may change depending on the upgrades. For instance, the Features include a Power-tilt-and-slide moonroof, but I upgraded to a pano roof.
Hi,
I can confirm this. Both mirrors have auto-dimming. I have a 350h with premium package.
I understand your concern, because the guest side mirror doesn't work EVERY TIME IT SHOULD BE! So basically, i have both mirrors worked at the beginning. Then at a time point, after i made some adjustment on the position of each mirror, only left works! I think probably that's a issue due to i set the guest side mirror too low. Then i try to pull it up a little bit and then both works.
So try to raise up or adjust your guest side mirror a little bit and try again.
The following 2 users liked this post by dklanecky1:
SkiRockies (02-11-22),
unkind2cat (02-11-22)
dklanecky1 (02-11-22)
