Compact spare tire
No enough room for spare under floor. I have Modern Spare
I bought the Modern Spare tire and jack in case. It is very good quality and the case is nice. I can put the jack and lug wrench under the floor. I will put the spare tire in the NX on long trips; it is pretty big, and it takes about 2/3 of the rear spare. But you could stack items on top of the case. The case is a padded material case with a nice handle. I am changing to non-run flats when my tires start to wear. I have 20 inch tires. I alos have AAA Premium road service
YMMV,
MidCow3
Yes, @lsft shows that there is not enough room to install a spare. Great video of under the floor of 450h+ though: https://www.youtube.com/watch?v=Oo4MXIL27sk Thanks @lsft for your great videos
YMMV,
MidCow3
YMMV,
MidCow3
And the case I got is not padded, just a simple case.
Hello MidCow3, have you tried to mount the spare to see if it fits? I ordered a full kit for my 2022 350H. They shipped a kit with a scratched wheel. I contacted and they replaced the scratched wheel with a new one. So I tried again (to fit test the wheel) but the jack was too low that it could not raise the wheel off the ground. They offered to send a higher scissor jack (that won't fit the foam case for the jack) or use a 2x4 wood block. I am waiting to fit test the spare wheel first (need to borrow a floor jack from my brother) before I decide what to do.
MidCow3
hth (11-09-22)
I took the tire out of the case and it looked good. I did not try to mount it. I did go on a long raod trip with it and it takes up a lot of space but I still had enough room for suitcases and everything, but used one backseat. Three adults. If i need it mounted will use AAA,
MidCow3
MidCow3
I placed the spare in the trunk; it takes quite a lot of space when I closed the rear lifted gate with the cargo cover installed.
I have AAA plus with 160 mile tow trips but I need to practice first because I often hike in areas without phone signals. That is why I wanted to fit-test the spare wheel. Clearly the jack did not work for me as it was short too raise the wheel off the ground. This makes me eager to fit-test the wheel.
YMMV,
MidCow3
hth (11-09-22)
Get AAA. Tires rarely have blowouts and flats; when was the last time you actually used your spare tire? Get AAA and get towed on those rare occasions. There is no room for a spare tire. No need for a jack or a pump with RFTs. However, when my sort lived RFTs wear out I will replace them with other, better riding, lighter weight ( i.e. better mpg) tires and use AAA if I have a flat or blowout
YMMV,
MidCow3
YMMV,
MidCow3
tires 20
I will probably change around 20K and I only have 2,500 miles now. Only one good rood trip and I don't drive that much.
YMMV,
MidCow3
Doug007 (11-10-22)
The issue with relying on AAA or Lexus is when driving in remote areas like many do. We have a mountain house and drive on fairly remote dirt roads in the high country of Colorado. I for one purchased a scissor jack/lug wrench kit, plug kit, and have a small electric pump in the vehicle. Outside of the very rare tire-destroying blowout, that should get me going to wherever I need to go
IEXNS (01-05-23)
IEXNS (01-05-23)
IEXNS (01-05-23)
YMMV,
Midcow3
P.S. - One guy reportws the jack didn't raise the car high enough. I haven't tried it yet.
Doug007 (11-13-22)
