OEM Puddle Lights
#46
CruiseGuy. Finally got my 350H Ultra Luxury (Canada eh!) 5 days ago and am really enjoying the car. It too didn’t come with puddle lights(!) but the plastic blanks are on the front doors. From your note I’m reading that the wiring was present, just not plugged into anything. Is that correct? Second question. When you indicated that you pried up on the top right corner of the blank is that on both blanks or was it a different corner on the passenger door versus the drivers door? Would love to add these lights as you did. Thanks for your response.
take a credit card, jam it in there, and pry away. The clips aren’t soft, so they won’t break off - very robust. And it doesn’t take a lot of force to remove them either. A credit card was all I used. I started from the side, and then once the gap was big enough, moved to the top. The blank just came out. No fuss, super simple, and I don’t see any way to even damage it.
The blank has a spot for the wire/connector, it’s just resting in the blank. Press the clip, wire comes out. Grab the light, put the connector in (can’t screw this up either, it’s keyed) - and just pop back in. It will simply go back in, there’s no way to do it wrong.
I’d say just grab a credit card and pry away. Start where it fits and you’ll be fine!
Machder (01-01-23)
#47
I know it’s not directed at me, but I just purchased and installed them myself. Honestly, it’s a job that is so easy, you can’t screw it up.
#48
Also, any chance you opted for the illuminated cargo sills as well as I would love to see a practical picture installed?
Thanks in advance!
#49
It's a VERY easy to do, it makes the task harder to do with sore artritic fiingsrs and and back lower back. I should have asked my neighbor for help, he is younger than I am.
#50
Nx350 executive
Mine came blocked, i removed it and there is a plug. You think if i get a puddle lights they will work? Or any other settings to do ?
#51
Puddle lights are no use here in CA because we are in a severe drought.
Batty (01-29-23)
#52
Note:- each of the two puddle lights will have a Left or Right marker on it - ensure that you fit each light to the correct door.
#53
Mine also came like this and I took the cover off but there is no harness behind it. I even popped off the lower part of the door panel and did not see anything. Anyone know if I can still add puddle lights?
#54
#57
First of all Thank you to all members about this front door puddle light as I have no clue it was a blank and sure enough there was a harness behind it. We must have at least 6 Lexus RX350 in the past and all have the exact same puddle light and I was shocked that it didn’t have it on the NX350H. I’m actually sick of the Lexus and the F Sport protector light from our RX350 so I’ll be installing a high power led which will be much brighter than these projector light.
@Jeff, one of my harness wire was not plug in to the blank and it was tucked all the way on the side. Did you actually remove the door panel to see if the harness was there? I’m actually surprised to hear that you couldn’t find it as I thought for sure all NX trim should have that harness. Sorry I couldn’t help much and I guess I got lucky with the harness being there behind the blank.
Machder (01-01-23)
#58
Finally got my puddle light installed and as mentioned before I didn’t go for the Lexus logo as it’s not bright enough imo. I used the same led light kit that I use on our RX350 and it is much brighter, Thanks again from all members for your input otherwise I wouldn’t have known that our NX actually has a puddle light connection ready.
The following 3 users liked this post by Dino2K:
#59
Machder (01-01-23)
#60
I pulled the blanks off and I too did not have the wires connected. I poked around and couldn’t feel any wires so I guess I would need to pull the lower panel away to find the connector.
For those that had to search for the connector, was it over by the speaker?
