OEM Puddle Lights
#91
#92
They should not, but I found a few reviews where the cheap aftermarket light immediately caused a fuse to blow due to short. I guess the luck of the draw ion the cheap QA area. One could test for a short, I suppose, before installing.
#93
My 2022 NX-350 does not have puddle lights but I want to add just LED lights, I do not want to projector style lights as I don't want a logo on the ground. Does anyone know where I can just buy the LED lights that would be plug and play? All I can seem to find is the style that projects the logo on the ground.
#94
#95
Thank is exactly what I am looking for, can you send me a link of where you bought them? I don't want to cut any wires, I just want them plug and play and that looks like what you have. Thanks for the help with this.
#96
Your very welcome and I’ll try to send some info through PM as I don’t want to clog up this thread,
#98
#99
#100
So you have OEM puddle lights? The projector or just lights? If you have lights you just swap bulbs as along as they’re 194 LED style bulbs. If you have the projector ones it’s just plug and play. All you need is a flat head screwdriver but if you have pry tools that’ll probably be better. On the drivers side pry the light from the right side and passenger pry from the left side
Dunerking (02-14-23)
#102
Hi,
Danny200t or anyone else - Do you happen to have the part number of the original lamps you took out ? These would be the stock, non "Lexus" projecting ones ?
I too have a CND Vehicle, tried to find it on-line but I get multiple part numbers and the dealer has no clue. I am trying to source the standard lamp.
Thank you !
Thank you !
#103
My 23 450h+ came with them already installed in Japan. This is what I have. I hate them. There is not enough light to even see anything if there was a puddle. Thinking about swapping them out for plain lights.
