Michelin tires
5th Gear
when I take delivery, I plan to have Michelin 20" tires installed to replace the run flats.
has anyone else done the same thing?
is Michelin the best choice?
I was told at the dealer they went with the run flats to reduce the weight of the vehicle by not having a spare and squeak out a higher MPG to satisfy government mandates.
Just curious what your plan for a spare is. When the run flats wear out, I'd like to go with a traditional set as well, but will definitely need a spare. I'm hoping Lexus or another vendor comes up with a retrofit compartment that one will fit in (if they haven't already).
though I think the runflats are for packaging as well especially for the hybrid trims where they need extra space for batteries and hybrid components?
When my run-flat tires need replacement, I probably will get non run-flat tires, and buy a sealant/inflator kit like this one.
Only 700 miles on my NX350h. Averaging over 40 so far and many local trips getting over 50 mpg. The run flats are a bit noisy, especially on open road, interstate etc. Will keep till they get worn and hopefully by then there will be some way to temporarily fix a flat on perhaps Michelin. 18” wheels etc.
The NX still rides great overall, but these run flats aren’t the long term answer.
but in 20+ years of driving, neither I nor anyone in my family or friends have had a blown out.. I'm sure it can happen but not really concerned...and tpms sensor is like only $40 ..so not big deal if it goes and it's less than price premium of RFT even disregarding the noise of them
if I do get a flat/blow out that prevents me from driving, I'll just call roadside for a tow/flatbed to a tire shop
When my run-flat tires need replacement, I probably will get non run-flat tires, and buy a sealant/inflator kit like this one. https://www.amazon.com/ResQ-71-063-0...0BJ2TBL2&psc=1
Have been a big fan of Michelin tires for a long time. Will probably go with those.
Will switch to normal tires at some point. Maybe immediately, or maybe after the first set is used up. Primarily a wife decision...
First line of defense for a flat will be roadside assistance. Owning this is probably cheaper than replacing run flats.
Next line of defense will be patch kit and inflator to see if we can limp home. (if roadside is unavailable or too slow in some remote area)
Last line of defense will be fix a flat. Yes it can be a mess to clean up etc. but will likely never get used.
Some people will even throw an actual spare in the back if/when traveling to very remote areas where an unrepairable flat could become dangerous. Remote doesn't have to be offroad. This isn't in our plans but understand for those that do. At this point you are probably also bringing spare gas, food, etc.
