Issues with bluetooth, Samsung S22 Ultra
10th Gear
Hi all,
I have a 2022 NX 350. I got my NX in February and there were software glitches with it. One of them is that the car will rename my Samsung S22 Ultra to Passive. Then when it names it passive it doesn't have my contact information and basically, I can't use the phone at all. The dealer looked at it and at first, they were stumped but apparently, there were other users having the same issue along with their profiles not being loaded, which mine did too from time to time. They issued a software update and supposedly it addressed these issues and for a while the car has been great, but now starting yesterday it is renaming my phone again to Passive and not loading my information. Has anyone else had this issue and if so, were you able to fix it? If not I guess I go back to dealer and see what they can come up with.
Hi all,
10th Gear
It has nothing to do with using Android Auto or the Lexus Navigation. It has to do with my phone not being recognized as it should be and instead being renamed PASSIVE and not loading any of my contact info or anything. It's annoying. It will do it whether I'm using the Lexus Navi stuff or Android Auto.
10th Gear
I have removed and re-added the phone a few times. I even did it with the Lexus service guy in front of me and when I restarted the car, boom PASSIVE. So I did reset the network connections on the phone. So far it has been good. Hoping it is fixed now. Thanks for the help. :-)
UltraDad (06-30-22)
I get the "passive" notice with my phone too, but I've been assuming its indicating those functions have been transferred to Android Auto (the "Passive" text IIRC is always accompanied by the AA logo when I see it). I go into AA and I can do all my calls and messages there. My wife's phone is not set to use AA, and when she uses the system all her calls and messages come thru the Lexus interface instead. I may try some playing with the settings, like temporarily turning off AA when not needing it to see if the functions transfer back to the Lexus Interface.
Tried clearing Bluetooth cache as suggested, but there is an issue with android 13 where the Bluetooth clear cache and clear data are greyed out. I am hesitant to reset the network connections because that wipes out all Bluetooth, Wi-Fi and Mobile data settings.
The issue I have with the passive problem is that when I connect to other devices after being in the vehicle my phone name is announced and displayed as passive. When I look at my phone name Bluetooth/advanced settings/phone name the name is correct (not passive). If I edit the Bluetooth name by deleting a character and the re-adding the character and then saving, then the phone name is displayed and announced properly. But when I reconnect to the vehicle it changes back to passive. So, somehow the Bluetooth device name is getting changed in the android software. Quite annoying!
Lexus has a "Connected Technology Support" website that I learned a lot from as it seems overly complicated and I'm pretty tech savvy. I don't even think some dealerships know what's going on . That and there are some obvious bugs in the software. Here is the website. Only 2022 models are on there I believe but they use the same software on 2023's of course.
https://lexusconnectedtechnologysupport.com/lexus/home
There is some good,not great ,info on there with Android ,Carplay ,Profiles ,Digital keys and such.
The Lexus App uses bluetooth for the phone calls /messages and uses Wifi for Android Auto. Android Auto doesn't use bluetooth as Bluetooth cannot transmit enough data to support AA. That's why when you switch to Android it says " Passive" as to the Lexus App it is passive to AA and why a phone although the phone is named in the Lexus App S22Ultra or whatever and that is for the bluetooth connection.
Yesterday's problem. I couldn't turn off the Android Auto WIFI connect to phone. Needed to set up my FitCamX dash cam to the phone which also uses wifi and only 1 wifi can be connected to phone at a time. I would turn AA wifi off and set it to not auto connect. The lexus app would over ride me and reset wifi on my phone to AA to auto connect again within 5 seconds and kick my FitcamX wifi off.
After researching online the work around was to disable the Android auto app .After disabling Android Auto App ,the car wanted me to put in the password and touch key to the start button to start,which I need to do to turn the cameras on, until I enabled AA again. Then they said the password was wrong,which I know for a fact it wasn't and had to reset password. So I would have to go thru this every time I want to connect to the cameras now or pull the Micro SD card . My fix ,for now,is to delete the FitCamX App from my S22 Ultra phone and just use my old Note 10 phone to connect to FitCamX Wifi for the cameras.
