Will the Rav4 hybrid high voltage corrosion issue affect the NX hybrid models?
Am I correct in assuming the current Lexus NX hybrids use the same high-voltage connection to the rear drive units that recent Rav4 hybrids use (Im still waiting for delivery of my 350h)? In which case we can expect the serious corrosion issues some Rav4 owners have in that component will eventually also affect the NX hybrid models?
There is a massive thread about this at https://www.rav4world.com/threads/hi...roblem.318314/ and the half-assed modification to the plastic covering Toyota implemented last year isn't looking like it will be of much help preventing the corrosion. Sufficient corrosion in this area will make the vehicle inoperable and require replacement of that entire high-voltage wiring harness potentially at major expense since it is covered only by the basic warranty (not part of hybrid coverage according to Toyota). Perhaps most concerning is Toyota's poor response thus far to the issue (hence the class action lawsuit currently happening in Canada). The issue will be of most concern to owners in those parts of Canada and the US where the roads are heavily salted in winter.
It would appear that the issue with the RAV4 Hybrid primarily has appeared on vehicles used in areas where salt has been used on roads during the winter, including the northern parts of the US and Canada. It also appears that, before the corrosion of the cable caused problems, the vehicles were exposed to those conditions for 2 or more years. Most of the vehicles with the failed component seem to be from model years 2019 and 2020. I suspect that, in the next year or so, we will be seeing 2021 RAV4 hybrid vehicles with the same cable failure.
Since the NX Hybrid shares so many of its components with the RAV4 Hybrid, I can only assume that it is using the same cable as the RAV4 Hybrid. With the NX Hybrid first becoming available for the 2022 model year, I would be surprised if there are already any examples of that cable failing, but I won't be surprised to see examples of the cable failure starting to emerge in the next couple of years.
I am surprised no one has responded here. I believe the hybrids have the same amount of panels underneath, so less chances those cables will be exposed directly to the elements. I wonder if from a design perspective though those cables are routed like they are in the RAV. Hopefully someone with some knowledge is able to chime in here.
I would like to see some pics or a reference of new parts over the 2021 Rav4 also vs part# for the NX. If it one if so certain, I would then to think they could share how it is known or or documentation to show the updated design for the NX.
From what I can see from under the NX, it looks just like the Rav4 2021 hybrid pics. The cable attached upside down with a short curve of the cable going back into the top of the car. It seems to have the same underbody hard plastic covering pan like other Rav4 hybrids also. I am not how new or if this pan has always been there or is part of the 2021 fix.
There may be, of course, some better connector improvements that are hard to see. I did not feel comfortable putting my hand on the back side to feel if it has the same cutout fix for drainage of the new connector. I assume yes, since it is a Japan 6/22 build date.
I drive in Colorado and we tend to not have much rust or corrosion issues, so I am not likely to see the issue as in other areas. I suspect most of the damage was the collection of the road salts been keep in a ionic solution by the lack of drainage. Just having the drainage cutout and the road cover probably reduces this to a manageable level. Not a chemist, but if the road salts are dried there should just be typical atmosphere humidity for a chemical reaction to take place - i.e. very little to almost none in Colorado. And normal rain driving should wash some of it out with the same action that put the road salts on the connector in the first place. I guess look for rain puddle. LOL
Here's a picture
I don't know what the underside of the RAV4 looks like, but this is what the underside of my NX350h looks like...
You be the judge.
You be the judge.
Considering that the RAV4 owners who have experienced the corrosion issue with the cable did not have the issue appear until after their vehicles had been driven through 2 or 3 winters, I would guess that, in a couple of years, it will be likely that there are posts here with the same issue from NXh owners.
When I was doing some research on this issue, I saw some pics of the new connector with the large cutout on the back side of the connector. It def will drain and not break open by the water freezing in it again. It seems Toyota's engineers think that cutout and with the pan cover is enough. I hope
I did purchase the US Lexus Financial Service VSA for 10 yr/125K. But not sure if it will cover this issue. They seems to claiming a corrosion/maintenance issue as an out not to do the repair. Probably not a deal breaker here in Colorado, but def would have been a stronger potential deal breaker to consider for some areas of North America.
At least the connector does not "fall off" as some other Toyota items have been doing lately and even harder to fix. LOL
When I was doing some research on this issue, I saw some pics of the new connector with the large cutout on the back side of the connector. It def will drain and not break open by the water freezing in it again. It seems Toyota's engineers think that cutout and with the pan cover is enough. I hope so.
But it also appears that this is just a temporary fix and that Toyota is supposedly working on a more permanent fix. Owners of the RAV4 Hybrid with that temporary fix report that it slows the development of the corrosion, but it does not stop it from occurring.
For those who want to spend some/lots of time reading, just about everything that is known about the issue, what Toyota is or is not doing, and what some owners are doing themselves is in a now 83 page long thread on the RAV4 World forums.
