extended warranty and maintenance package for NX450h+?
@lesz thank you so much for the insight! This is the part I'm trying to figure out the actual maintenance cost, and having a hard time.
How much does the following maintenance usually cost? Looks like these are the comment items on the maintenance schedule
- Replace Engine Oil And Oil Filter
- Replace Cabin Air Filter
- Rotate tires
- Replace Engine Air Filter
- Replace Brake Fluid
- Clean HV Battery Cooling Intake Filter
I took all of my Lexus vehicles to the local Toyota dealer for regular maintenance. They charged me $50 (until recently, it had been only $40) for full synthetic oil changes with a $10 coupon that was always available. The charge for the tire rotation was $10, and the brake fluid change was a little over $100. All of the inspections were done at no charge. That adds up to under $300 for a 3 year period of time. (The engine air filter and cabin air filter can be replaced yourself in less than 5 minutes and they can be bought at any auto parts store, Walmart, etc. for less than $25.)
Had I had the same work done at a Lexus dealer, it likely would have cost between $500 and $600 for the same 3 year period, but that is because Lexus dealers operate their service departments based on the belief that, if people are willing to pay a premium price for a Lexus vehicle, they will also be willing to pay a premium price for the same service that could be done much less expensively at a Toyota dealer or with an independent mechanic. When the dealer is trying to convince you to buy the pre-paid maintenance plan and when they tell you that required service will cost $300, $600, or $900, depending on the service interval, they are getting those numbers by including things that Lexus does not recommend or require or that are not all needed.
Helterran
10-04-19 04:13 PM
DanBryant
ES - 6th Gen (2013-2018)
01-03-18 10:52 PM
