The 2022 NX and Theft
#46
Cheers
#47
The new Lexus key fob has a really shorter rang of operation, therefore It's the 1st step in the right direction, also look like they are now using the rolling keys code so it will make it harder for the theft. But an "OBD port lock", "TAG system", "Air Tag", "Samsung Tag" are you best friends
FastFord (11-07-22)
#48
The new Lexus key fob has a really shorter rang of operation, therefore It's the 1st step in the right direction, also look like they are now using the rolling keys code so it will make it harder for the theft. But an "OBD port lock", "TAG system", "Air Tag", "Samsung Tag" are you best friends ![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
#49
Other than that, towing is the last resort for the thief.
#50
I would allocate a budget and, speak to a reputable car security shop.
There is no one solution, it’s all about layering and prevention. Like park in well lit areas, garage, steering wheel lock, never give your remote to repair or service shops with a physical key, always take it out before etc
#51
You can install fake obd port and obd port lock over it. Or, one of them. Immobilizer from Lexus probably is not the best idea since it is know to thieves and methods to defeat it. There are some very good aftermarket solutions like Ghost or Masterguard. Can be just mechanical kill switch or, some inexpensive alarm with immobilizer.
I don't want to be the first NX owner to test Ghost II immobilizer. If anyone has experience with this product, appreciate if you can share the experiences and issues.
#53
Are these tags really any good for tracking in real-time? I have seen conflicting reviews of these devices on YouTube and wondered if anyone on here had some experiences to share. I have a Samsung phone so would probably be more interested in the Samsung SmartTag.
Thanks.
#56
Thanks for the reply. That means I have to be quick to use the fob to close the door before someone scans for the code on the fob.
#57
Someone mentioned Lexus app earlier in this thread. On NX350H models with no digital key option (I think digital key is only available on the luxury models), can you start the car, lock and unlock the car with the Lexus app via Remote Connect? Does it do that through Bluetooth or Cellular connection?
I'm also wondering how safe it is in comparison with using the key fob.
#58
Here is the section of close & lock from the manual:
Close & lock (walk away) *function
When the power back door is open, all of the doors will be locked when the power back door is closed.
Before driving
Entering/exiting the vehicle and loading luggage
INFORMATION
■ Close & lock (walk away) function operating conditions
This function can be operated when all of the following conditions are met:
● An electronic key is not detected within the vehicle.
● All of the doors other than the power back door are closed.
● The brake pedal is not depressed.
● The power switch is off.
■ Hands free close & lock (walk away) function* operating conditions This function can be operated when all of the following conditions are met:
● The hands free close & lock function setting is on.
● The Hands Free Power Back Door operating conditions are met.
■ Situations in which the close & lock (walk away) function may not operate properly In the following situations, the close & lock function may not operate properly:
● If the switch on the lower part of the power back door is pressed by a hand which is holding an electronic key
● If the switch on the lower part of the power back door is pressed when the electronic key is in a bag, etc. that is placed on the ground
● If the switch on the lower part of the power back door is pressed with the electronic key not near the vehicle
#59
From the manual, it said as long as power back door is locked, all doors will be locked. Every time I step out of the vehicle, Do I have to lock the door with the key fob before walking away? I thought if the door is closed and key fob is not detected inside the car, all doors should be locked. I guess I’m wrong on this.
Before driving
INFORMATION
Before driving
INFORMATION
mandz21 (11-19-22)
#60
I have been researching the usefulness of the various "tags" that are on the market so as to provide some method (albeit a relatively low-tech and cheap method) of tracking the car. I have a secure garage where the car is housed overnight but would like the extra reassurance of being able to pinpoint the car should it get stolen from elsewhere.
Thanks.
Thanks.
maybe get both, for less than 100$.
