Wireless charging issue with iPhone 13
This seems to affect the iPhone 13 more than other phone models.
For those that are affected, does it still cause your phone to heat up as if it were charging even when the orange light is blinking and it's not charging?
That would make it so you can't even use that slot as just a phone holder.
I don’t have any problems with my iPhone 13 Pro Max (with Apple leather case) charging unless it moves when I take a turn at more than casual speed. If it moves I just reposition it and it’s fine.
I’m going to place it on the charger while parked and then try putting some rubber dots around the border and will see if that keeps it in place.
redhot47fl (08-11-22)
My friend's Honda Civic 2022 Touring with a wireless charger does the same thing.
My NX350h Executive (Canada) does the same thing.
Interesting fact is that it charges my wife's Samsung phone just fine.
I have a non-Apple MagSafe leather case on my iPhone 13 Pro Max. Sometimes the phone charges just fine. Sometimes it charges for a minute and then stops. I'll shift it around and it will connect again. A minute later it will disconnect. There doesn't seem to be any reason for the inconsistency. There also doesn't seem to be a sweet spot on the charging pad.
Dkaplan (08-18-22)
Could we solve the alignment issue by sticking one of those aftermarket "magnet rings" onto the charging platform? I mean those metallic rings that conform to the MagSafe patterning, so that the (MagSafe-compatible) phone will stay in place.
Here's what I did. I might use 3m tape to secure the MagSafe charger. Finally, the door closes with the MagSafe, iPhone 13 Pro Max and Apple leather case.
small 12-volt adapter
Apple MagSafe
Added 3m two-side tape. I’ll let it set over the weekend and hopefully it’ll stay put when I lift up my phone.
Apple MagSafe
Apple MagSafe
Apple MagSafe
NX200Tvadr
NX - 1st Gen (2015-2021)
09-07-22 01:09 PM
JedWare
GX - 2nd Gen (2010-2023)
15
03-11-20 01:50 PM
ISmikeIS
08-16-09 02:55 PM
